Carving Benches
Carving Benches
Carving Benches
Jennifer@Indy.USA
>I just posted this over on the carving side and thought what the heck I'll post it here too since some of the gang here carves and burns at their benches.
_________________________________
Hi Everyone,
I've just recently gotten into doing a bit of carving on my turned bowls and platters and such and am curious to see what sort of setup you dedicated carvers use as your carving bench. I find that just using my workbench and the metal shop stool that I have is not conducive to carving at all and am pondering an alternative set up just for when I'm carving. I've got my power caver hanging up and to the right of my bench and that seems to be a good place for it....but I'm thinking of building some sort of platform of doubled up 3/4" ply that I can attach to the bench that has a sort of horseshoe cut out in it so I can surround myself with benchtop. As it is now...I can't get my stool (which is terribly uncomfortable) close enough to the bench to even get my knees under it. If any of you have a picture of your carving area set up that you wouldn't mind sharing I would be so grateful. I really love this dabbling in carving that I'm doing and I think I'd enjoy it even more if I didn't walk away from my bench in pain from leaning over, and straining all the time!
Thanks in advance :)
Jennifer
Re: Carving Benches
Re: Carving Benches
Ed Kelle
>I don't have a special bench or anything, but I do use sandbags to help support and cushion the work. Double layers of grocery store bags of sand, covered with 2 layers of old tube socks. Had then for years, initially used them on stone carving, they work great for wood. Just the right size to mold around pieces and having a few lets me support my arms at times also.
Re: Carving Benches
Re: Carving Benches
RobinCorell
>I do a fair bit of carving on my furniture. I don't have a dedicated bench or carving area and have in the past used the end of my table saw table. It has a router insert and by removing that I gain a convienient way to clamp my work. lately I have been carving on my drill press. It is a bit on the uniqe side. It is a radial with a 24"x24" table with "T" slots and weighs in at about 400 lbs. The one constant seems to be my chair. I use an ond swivel office chair with an adjustable height base. I also have a rubber mat in front of the table and I find it gives enough resistance to the wheels. The adjustable height base lets be be down close with palm tools or heigher up for mallet work. An advantage of using the drill press is it also has a work light. I do all my carving with edge tools but I suppose if I were power carving I could even use the chuck in my drill to hold the power unit, The drill head can swing 360 degrees and has 27" clearance above the table. in case you missed it that was a bit of a gloat. :)
On the topic of holding irregular work, sand bags are very helpful. I use the leg of worn out jeans. I had some that were sewed on one end and then folded and glued on the other end the ones I have now are folded and glued on both ends. I also find having bags with diferent amounts of sand to be helpful. I have done a lot of grinding on bronze castings in the past using these bags and on hollow forms a smaller bag that can fit inside helps keep things from moving around a bit.
Robin
Re: Carving Benches
Re: Carving Benches
Curtis TX
>I built a mini bench. This "carving" bench sits on top of my main workbench. I clamp it in place. Works great for carving. I find that I leave it in place even when I am not carving. Perfect height for sanding the bottom of a bowl or removing a tennon after turning. This is the only pic I have of the bench. If you look on the large bench you will see one of the holding forms. I put it in the dog holes and use a LV bench pup (?). I don't recall if that is the correct name but its the item that a uses a screw to clamp items.
Re: Carving Benches
Re: Carving Benches
AndiWolfe
>Jennifer - I posted a picture of my carving setup awhile ago on the carving forum. You can do a search through the archive.
Re: Carving Benches
Re: Carving Benches
Mac
>Hi Jenn.....I have done a bit of carving over the years and have found through trial and a lot of error.......that standing up to carve is a lot less tiring. As I use carving tools as well as power carving,standing allows one to put body weight into the carving,that seems to eliminate the back tension and you also tend to move around a bit more.You do have to have a clamping device at the right height for standing, but there are all manner of devices for that as you know.One of them is known as a tablesaw(a multi purpose device).Relax and enjoy it......Mac
Re: Carving Benches
Re: Carving Benches
Jennifer@Indy.USA
>Andi, Thanks. I found the picture of your set up and am wondering if it is attached to the bench or if it just rests on your lap? It does look like it would be good ergonomics the way you have it designed.
Thanks,
Jen
Re: Carving Benches
Thanks Robin & Ed
Jennifer@Indy.USA
>I love the sandbag idea. That sound like something that would be great for support and stability. Great idea!
Jennifer
Re: Carving Benches
Thanks All!
Jennifer@Indy.USA
Re: Carving Benches
Re: Carving Benches
AndiWolfe
>Jen - It's attached to my other workbench. The design is very comfortable for long sessions. (You can see a nerdy action pic at: http://andiwolfe.blogspot.com/2006/03/new-project-part-vii.html) It's specifically for power carving, but I do a fair bit of hand carving on each of my projects for the finishing details. At that stage, I wouldn't want to use clamps or anything that might break the piece, so this design gives me the option of putting cushions to brace the work. You can see some examples of my latest carved turning in progress at: http://andiwolfe.blogspot.com/
The bench design was adapted from a picture of Michelle Holzapfel's bench that was in a wood magazine last year. Terry Martin wrote the article. Can't remember the details, and I don't want to spend the time looking for it.
Re: Carving Benches
Re: Carving Benches
craig
>Have been lurking quite a while so thought I'd jump in on this one.
About 20 years ago I was looking for an old barbershop chair for the hydraulic componets. Didn't find the chair but discovered an old operating table. Disgarded the platform but the base is perfect for a carving stand. As well as height adjustment, it also tilts in any direction you wish. Best of all its stainless steel and is on wheels ...
BTW- have been turning seriously since the mid 80's when I attended a windsor chair class with Mike Dunbar, when Ernie Conover first introduced his lathe. Craig, in rainy northern Vermont
Re: Carving Benches
Re: Carving Benches
Carole Valentine
>Hmmm...drill press! That might work just great. Thanks!
