Making tools
Making tools
Making tools
Don Tewell
>OK I need some help. I am going to attempt to make a couple of tools. How deep should the steel go into the handle? I will probably use some kind of epoxy but don't know how deep to place the chisel. TIA for all the help I know I'll get.
Re: Making tools
Re: Making tools
>I use 3 inches for most tools unless thier small. The weak point is where the ferrule meet the wood so I make sure the metal goes at least an inch beyond that.
Re: Making tools
Re: Making tools
Allen Neighbors
>I insert the steel at least three inches, but I don't use epoxy, because I might want to replace it, or use the handle for a different tool, later. I epoxied one tool into the handle, and now I am kicking myself, because I want to replace the tool.
I saw TD use heat to remove a glued turning from a bottle stopper for Ruth Niles, so I might try that.
I also use 3/4 inch pipe couplings for ferrules on most of my larger tools now. They screw on, and can be removed if necessary.
Hope this helps a little.
Allen
Yellow shavings pile up fast in Childress :o)
Re: Making tools
Re: Making tools
Don Tewell
>So instead of epoxy, just glue? Any particular kind?
Re: Making tools
Re: Making tools
>Heat will remove epoxy. I used to install inserts in laminate bows for sights, and stabilizers and when I needed to change them I would just screw a bolt into the insert and heat the bolt. The epoxy would let go.
Re: Making tools
Re: Making tools
Allen Neighbors
>I don't even use glue. I bore the hole just slightly small, and force the tool into it. Sometimes I grind the steel down just a little, toward a point, without pointing it, and taper the hole, by using successively smaller bits as I move towards depth. A few raps on the other end of the handle with a shop mallet will usually do the trick. Once in a while I have to rap it again, but that's isn't as much trouble as trying to remove a glue-in shaft.
Allen.
Re: Making tools
Re: Making tools
>Don what I've always done is drill the hole just a hair undersize. Then heat the tang of the tool to almost red hot and drive it in the handle. this is an old blacksmith's trick and works really well.
Re: Making tools
Re: Making tools
Allen Neighbors
>See what I mean about you, John? :o)
Thanks again for the good info.
Allen
Re: Making tools
Re: Making tools
RevDoug
>I used to make some golf clubs for fun. One of the best things that I learned from that experience is that all glues have a melting point. Most epoxies melt and release in the 200-225 degree area. That's a really low temp when you are talking about metal, expecially tool steels. Epoxy those tools into the handle. A torch or even a heat gun will heat the tool enough to release the tool from its handle.
Turn 'em round,
Re: Making tools
Bob Moffett
Re: Making tools
Bob Moffett
>John,
What is the benefit of heating the tool before inserting the tang into the drilled hole? I don't understand how this makes it fit any better.
Thanks,
Bob
Re: Making tools
Re: Making tools
>Bob This method is usually used for flat tapered tangs. You drill a round hole the size of the small part of the tang and then heat it up so it forms it's own shape. I've found that it works well for round tangs as well. You don't have to worry about splitting the wood. I also grind a short flat on the end of the tang so it burns it's own shape in the bottom of the hole and keeps the tool from spinning. I've never had to re-seat one and have had to drive them off when I wanted to replace the blade.
Re: Making tools
My Solution: *LINK*
>Don, here is what I did:
hope it is useful; if you don't want to interchange, heat up the tang and pound it in as John Lucas explained, a centuries old method that still is best for a fixed tool.
my $0,02
Jorge
http://www.woodcentral.com/cgi-bin/turning.pl?noframes;read=106881
Re: Making tools
Re: Making tools
RobinCorell
>You need to know what kind of steel you are using for this trick to work. It is not used just to fit a tang to a handle. With oil hadening steel it will make the tang soft so it will bend rather than break. With air hardening steel this trick will make the tang brittle.
Robin
Re: Making tools
Re: Making tools
Ron in Drums PA
>I soaked a bowl in DNA with a glue block expoyed on. The DNA desolved the expoy and the glue block came off.
Try soaking the handle over night in DNA and see if the tool comes out.
Let us know if it does.
Re: Making tools
Re: My Solution:
Bob Fawcett
>I saw Jorge's handle at the gathering. Its a great solution. Could be adapted to work with any type of tool.
