boiling bowl blanks
Bill Wallace
>Does anyone have experience with boiling roughed out green bowl blanks? Does it keep them from checking or just speed up the drying process?
boiling bowl blanks
Bill Wallace
Re: boiling bowl blanks
Carole Valentine
>I have used it on fruit woods which are subject to cracking. Don't know that boiling alone speeds up drying, though. I boil the blank for a couple of hours and let it cool to room temperature in the water. At that point, I usually let it surface dry then put it in DNA to speed the drying process.
Jim King
>Bill: I have boiled thousands of blanks and it does reduce cracking and increase drying speed. For a four inch blank a minimum of 8 hours is our rule but then again a rough turned peice we use the rule of four hours if it is an inch or less thick. I will not waste my time on waiting for bowl blanks to dry and finally have them split. Contrary to many turners I dont want to see dry blanks. Virtually 100% of our turninings end up on airplanes in transit to the States. It was a brutel lesson to send turning after turning and have them arrive cracked when we thought they were dry. Now with the roughed blank boiled and dried properly we loose none in the bone dry atnosphere of an airplane. Take a look at this article about boiling. http://www.exoticwoodworld.com/index.php?c=static&sc=process
Steve Worcester
>The article 2 he references is probably the best I have seen. It was written by Stephen D Russell, and we published it in our newsletter some years ago
http://www.dallaswoodturners.com/NEWSLETTERS/2003/DAWNLApril2003.pdf
Ina convenient and printable form (I don't like reading long articles off of the web)
Steve Worcester
www.turningwood.com
Off a web page anytime :)
Dave Peebles Lyons, Ohio!
>Steve,
You must be on a high speed connection. Because I would rather read off a web site any day, than wait 10 minutes for a pdf to load on dial up. Ahh the joy of living in the sticks. :)
Dave
Philip F Duffy
>Boiling per Russel's method is 1 hr/inch of thickness on green wood. It works to keep the distortion of the bowls to a minimum and accelertes the drying process. Try it outside, if you can, or clean the stove afterwards. (Keeps the peace in the kitchen.) Phil
Charcoal
Bill Hale / Woodspinner
>Don't do as I did. Set up a barrel and a large burner, worked great. Put the blanks in, got them going and got company. Went and visited, had a few beers, ate a little supper and had a few beers. Got up in the am and found a nice batch of charcoal in the dry barrel.
Bill in Casa Grande, AZ.
