lathe mobility
lathe mobility
lathe mobility
Dennis Taylor
>does anyone have a mid size lathe, mine is a Jet 1642, that is on wheels or some assembly to allow it to be moved around the shop?...mine is against a exterior wall in a garage/shop, and need to have the ability to move the lathe around in the shop, now is isn't on wheels and sliding it around isn't easy work, is there any suggestions out there?...thanks in advance...Dennis
Re: lathe mobility
Re: lathe mobility
Phil Joines Krum, Texas
>We have a Dlta Industrial on the double locking wheels form Woodcraft. They do allow some vibration with large out of ballance peices.
Our club lathe, a Jet 12", has the cast iron legs. One of the members made a set of wheels mounted on angle iron that can be quickly installed and removed. They are used only when moving it from it's storage location to the meeting room. It's a lot more stable. I don't have any pics of it. I'll email the guy who built them to see if he has any electronic info.
Re: lathe mobility
Re: lathe mobility
DaveL
>Dennis,
I have my Powermatic 3520 on a Vega Machine Mover, when you aren't moving the lathe it sits on the ground not on wheels so the lathe is very stable. I ordered it from Packard, it is not in the catalog you need to call them in order to order it.
Dave
Re: lathe mobility
Re: lathe mobility
Gary A.
>I built the set of castors for the club lathe that Phil Joines referred to. The castors were purchased from Northern Tool & Equip.
They are 8" with 2 of the castoring and 2 rigid so that one end can be steered(?) where you want it. The 8" allows you to effortlessly roll over cords or carpet edges. The rest of the installation was welded up from 1" square steel tubing in such a way that the castors flip up when your done moving the lathe so that the lathe rests on the floor on it's feet.
One consideration to keep in mind if you are going to build a set for your lathe is to design the castors to be on the ends of the lathe so that you can easily move the machine through a 30" doorway.
All the best,
Gary
Re: lathe mobility
Re: lathe mobility
>Dennis my method isn't useful for daily moving of the machine but worked well to move it from house to house. I built carrieges that attach to each end. I raise that end of the lathe with a rolling floor hydraulic jack. Then place the wheel set under it and lower it down. I used 8" pneumatic tires for ease of rolling over the trailer ramp. It worked so well I decided to load the lathe myself (before my friend got there). I pushed it up the ramp of the trailer. Once over the lip of the ramp it took off like a bat out of hell toward the borrowed truck I was using dragging me with it. Fortunately I was able to slow it down enough that it stopped when it hit the end of the trailer. I'll bet I had a funny look on my face as I fought that thing that outweighs me by 650 lbs. I'll be glad to send a photo of my homemade brackets if you need it. I would opt for set of wheels that you leave on but crank out of the way. I have on of the Vega movers on my Bandsaw and can highly recommend them.
