Re: $100.00 Grizzly chuck???Help
Gil Jones on Lake Seminole GA.
>If you are referring to the one that is a copy of the VicMarc 100, I have one, and it works fine. The machine work is about as good as the Vic, but it is not as smooth internally (maybe in time it will loosen up). Mine came with T-handled hex wrenches (8mm and 3mm). Neither size fit properly, but Grizzly did send me new ones that do work. It is worth the money, and so are the $17 jaws you can buy as options. Also, Grizzly did such a good copy job that all of the VicMarc and Grizzly jaws interchange on the two chucks.
Gil
