Re: Bushing Chart Pen Makers
eaglesc
>Mot charts I have seen were a waste of effort on the part of the author.
MFGRS part numbers don't cross refrence.
There are some kits sold by wood craft that are similar in appearance to the MFGRS but the bushings are different.This is probably one reason Woodcraft is discontinuing so many styles made by Berea.
Case in point.
Berea sells a "perfect fit" but make the bushings so it needs the "b" mandrel.
Woodcrafts version was called the
"convertible pen"
but could be made on the regular 1/4" mandrel.
I have seen posts stating there is a 10 mm mandrel for cigar kits not sure where I saw that.
Bottom line is most suppliers want you to use their bushings with their kits.
If you are not making your own bushings to match the components of each kit(or miking the blank to the dimensions ofthe components you may run the risk of a poor fit.)
This is possible even with the bushings that are made for each kit.
Bushings are a wear item, they don't last forever.Ammortized over the amount of pens a set will make they are relatively innexpensive.
