Home-made branding pen
Molly Winton
>I was forced out of necessity to finally make one of these branding pens two days ago. It wasn't hard at all after I got over the foot stomping and whining. Thank you John Lucas for your helpful information! I even used classy wood. The best part is it works!
Re: Home-made branding pen
Carole Valentine
>Ok. Now I am just going to have to quit whining myself and try it. That's a beaut, Molly. Did you just strip the plastic off one of those barrier strips?
>Molly What gauge wire did you use. I made several good ones and then one that would not work at all. I think the wire I used in that one was too large. It just would not heat up. I'm going to make one of your nail tips using one of my copper rivets. Now that school is out I have a little more free time so I'm looking forward to trying some fun things.
OB OBrien In Pensacola
>Looks good Molly. How did you or what did you use to make the wire clamp part. It only has two connectors. Sue wants to know (g) Thanks OB
>Carole If you remove the screws from the brass pieces and then cut through the bottom of the barrier strip with a razor knife they are very easy to get out. I worked and worked getting them out the first time, then I discovered this method.
Nice!
Barbara Gill, Remlik VA
Nice, but missing an important feature
Craig Daymon
>Molly,
Very nice burner, but after seeing some turners demo their new high-power burner, you are missing one thing that might help. They turned several handles and the ones that were the best for them had a "foil" behind the burner. (Foil as in the foil on a sword.)
Now this was a high powered burner that shot a 6" flame when it touched the wood, so you could easily get a bit scorched without the foil. The transformer was adjustable, so it could be tuned down. Still, it did a good job burning and worked quick.
-Craig
Carole Valentine
>OB and Sue,
It actually has 4 connections - one is hidden inside. The coonections are pieces from a barrier strip from Radio Shack with the plastic coating removed. Here's a pic.
What is the filler?
Carole Valentine
>Molly, what are the connectors seated in? Looks like some kind of epoxy?
Two are hidden
Carole Valentine
>The problem with previewing is that you always seem to see what you THINK you wrote! LOL
Answers to your questions.....
Molly Winton
>Carole, John already explained how to remove the metal part, but I'll reiterate it here. I just remove the set screws, and then the other part slips right out. I don't need to cut the plastic at all.
John, I used regular lamp wire. I'm not sure what the guage is.
OB, the wire clamp part is the metal parts taken out of the barrier strip from Radio Shack. There were three sizes of barrier strips at my Radio Shack. I used the middle size. John sent me some of the smaller size (thanks John), but they're almost too small for my fingers to manipulate.
So this is what I did... after removing the metal parts from the barrier strip I soldered the lamp wire to one end of two metal parts (henceforth referred to as the 'thingys'). I guess you could use the set screws instead of soldering, but soldering seemed more durable. I then inserted the wire through the 3/8" hole drilled through the pen. At the head of the pen I also drilled a 1/2" diameter recess about 1/2" deep to make room for the thingys. I then stuffed a cotton ball down into the hole to hold the wire steady and to plug the hole. To space the thingys apart I wedged a piece of toothpick down between them. Then I used JB Weld (a heat tolerant epoxy, found at the auto parts store) to fill the top of the pen being careful to not foul up the threads of the upper set screws. The JB Weld sets over night. To finish I attached a 1/4" phono plug at the other end of the wire. Voila!
For me the hardest part was soldering. I've never done it before, and there seems to be a knack. I'm getting better.
I hope that's not too garbled. Let me know if I can clarify anything.
Re: Answers to your questions.....
>One more thing. There are 2 or more types of JB Weld, at least at my store. I find the High heat version works very well. The others might but I didn't want to take a chance on my pens falling apart.
Ed in Leaside (Toronto, Ontario)
>You could call those metal thingys you removed "terminals".
If you'd like to send some pics and descriptive text for this, and the copper nail tutorial, I could typeset it (in Quark not Word) and generate PDF's.
Ed
Gil Jones on Lake Seminole GA.
>Very clear. Thanks Molly.
Ron in Drums PA
>Very Nice Molly
Would you be interested in doing a pictorial/web thingy?
I would list it here if you are interested wc.simplyturning.com
Molly Winton
>Thanks Ed. I can always count on someone to give me the 'technical' terms for all of my thingys, dohickies, thingamajigs, and whatchacallits. The hard part is remembering their real names!
Russell L. Babbitt Jr.
>I thought thingys, dohickies, thingamajigs, and whatchacallits, were technical terms.
>Thanks Molly; That's a good explanation, I understand now. Will make some for Sue (soon) Thanks Again. OB
They sure are for me!
Molly Winton
Lamp wire
Carole Valentine
>I read somewhere last night (don't have a clue where) that regular lamp wire is not a heavy enough wire for the wattage (?) that most burners put out and that a heavy duty wire should be used. Just something to think about.
