Grind pics?
Grind pics?
Grind pics?
TDaniel
>Unless someone posts some pics of their grinds we'll only be talking about mine tonight :). Come on folks, send your pics to RonS so we can have something to talk about.
TD
Re: Grind pics?
Re: Grind pics?
Allen Neighbors
>TD, I have the VS Delta 8" Grinder. I can't get my grind to match the photo I took of your gouge grind. Your Grinder is different from mine. Can you measure from the center of the wheel, down to the top of the V arm, and give me that measurement? I think that's where my problems may lie.
I took a close-up pic of your Varigrind set-up, so I could adjust the angle of mine accordingly. And Mitch gave me the other two measurements when I called that day.
Thanks,
Allen
Yellow mulch is pretty, in a large pile.
Dreamin' of a 1640....
Re: Grind pics?
Re: Grind pics?
Stuart Johnson
>TD, I would like to see some additional shots of your grinding setup with the varigrind.
Re: Grind pics?
Re: Grind pics?
Allen Neighbors
>Here's the pic I took of TD's varigrind, showing his adjustment angle.
Allen
Re: Grind pics?
Re: Grind pics?
Allen Neighbors
>Try again.
Re: Grind pics?
5 1/4"
TDaniel
>I measured from the center of the wheel to the highest point of the base bracket that the V arm slides into. Let me know if you need more info.
TD
Re: Grind pics?
Re: Grind pics?
OB OBrien In Pensacola
>Allen; Here's a picture of my varigrind. It's a John Jordan setting and works fine for me. Notice the difference between yours and mine.
Re: Grind pics?
Re: 1/2 inch bowl gouge top view
>Allen; Take a close look at the instructions that came with your woverline sharpening rig. Especially the part where you mount the grinder base on top of a 3/4 inch plywood base. Then measure the settings vertically down from the center of the grinding wheel and then horizontally to the front of the woverline. Then slip the gouge into the varigrind and set it so the gouge sticks out 1 and 3/4 to 2 inches from the end of the varigrind. Set the varigrind gouge holder into the sliding wolverline and adjust the distance till you get about a 40 degree grinding angle. I think this is the setting for my jig. Notice the swept back angle of the top view and the flat top on the side view. Hope this helps. Regards OB
Re: Grind pics?
Re: 1/2 inch bowl gouge side view
>This is the John Jordan bowl gouge grind, side profile.
Re: Grind pics?
Here's mine - top
Carole Valentine
Re: Grind pics?
Side
Carole Valentine
>Don't know how I arrived at this grind - just works for me. Very versatile.
Re: Grind pics?
Re: Carole- that's very close to ...
JamieDonaldson
>... the original Ellsworth profile, and versatile weapon!
Re: Grind pics?
Allen Neighbors
>Carole, do you use the Wolverine system, with Varigrind? If so, could you post a pic of the Varigrind that shows the angle adjustment? I'm looking for different setups to choose the one that will work for me. Right now, I'm getting catches right and left, and I think it's the way I have it ground.
I think the straight profile on the sides, like your gouge has, and OB's, will be better for a shaky handed guy like me.
Allen
Gonna grind this one away,
Or learn how to use it...
Re: Grind pics?
Carole Valentine
>Allen, I will take a pic of the varigrind for you tomorrow (if CRS doesn't get me!) Sorry, I did not see your post until tonight! Where were you last night when we had the Grinds discussion in chat? We missed you!
Re: Grind pics?
Re: Carole- I was out on volunteer
Allen Neighbors
>duties. We had a tornado come through our town Tuesday night, and I spent most of that night out on calls. I am a volunteer fire fighter, and we had to respond to a lot of downed power lines, missing roofs, missing people (they were found - only one injury reported)and small fires, started by downed lines, and leaking gas lines.
Then last evening, (there's an hour's difference in our time) I was out doing other things related to storm damage, until well after 9PM. I got into the chatroom, and I was by myself.
Sorry I missed the grinds chat. That's one I surely wish I could have made. I can't get mine to grind like yours or Terry's or OB's. Some measurement is off somewhere.
My tool is set at 2 1/4 inches in the varigrind. The V-point is 8 3/8 inches from the wheel. My varigrind is set to the same angle as Terry's. My wheel center is 5 1/4 inches above the V-channel. I'll keep trying, I guess.
Thanks for your help.
Allen
Grinding away, in Childress, Texas
