Mil drill bearings....
W.C. Turner
>are on sale again, in the May Enco sale catalog, DU510-1961, $2.39 each. Prices effective thru 6/30/06
Re: Mil drill bearings....
Sealed or shielded?
TDaniel
>Make certain you get the dowble sealed, not the shielded.
TD
Re: Sealed or shielded?
RevDoug
>TD, using the Southern spell check again?
Turn 'em round,
What are these and why would I need them?
Dave Belser
>Except to replace old bearings?
Is there some special use for these in turning?
- Dave
The only stupid question is the one you don't ask
Re: What are these and why would I need them?
Peter Teubel
>Due to the design of the drill, all the cooling air for the motor flows over/through the rear bearing. Since this style drill is popular amoing woodturners for sanding, there's alot of dust that gets in the rear bearing...which is NOT sealed and wears out quickly. The sealed bearings last MUCH longer because they prevent dust from entering the bearing internals.
Thanks, can I expect the same ?
Dave Belser
>I purchased a low speed Souix angle drill to use for sanding. I turn almost every day but don't use the drill that much unless I'm finishing a bowl with difficult grain. How long can I expect it to last?
- Dave
Ignore that :) I'll just read the next thread
Dave Belser
Did I say dowble shielded?
TDaniel
>I meant dowble shielded.
Kevin Gerstenecker
>Does anyone know if the Enco bearing Part # WC posted will fit the Sioux Drill also? So far, so good with my Sioux drill bearings. I keep it very clean, and blown out with compressed air, but I would just as soon order a couple to have on hand should one or both go south on me. Sort of insurance against down time. Like everything else, they won't go bad until you REALLY need to use it! Thanks for the great information!
