Re:Powermatic 3520
Re:Powermatic 3520
Re:Powermatic 3520
John Mcalevey
>I noticed on the Osolnik web site under options for the PM 3520B lathe that there is a tool rest height extender for the banjo. Does the optional bed attachment on the PM 3520B model lathe mount flush with the standard lathe bed or lower so that the swing of the lathe is more than 20"? Can anyone clear this up for me? Thanks JM
Re: Re:Powermatic 3520
Re:Powermatic 3520
Rick Davenport
>It mounts lower on pre-drilled holes.
Rick
Re:Powermatic 3520
Rick Davenport
>Or you can mount it level with the bed to add 18"
Re:Powermatic 3520
John Mcalevey
>Thanks Rick, When it is mounted lower does it give you a 24" swing? And is there a tailstock riser available similar to Oneways on the 1640? JM
Re:Powermatic 3520B "Highjack"
Eugene Soto, San Antonio, TX
>Looking at maybe buying the Powermatic 3520B. I am a brand new turner (well�not yet but at least a �wanna-be�) Why buy the 3520B? Well, I wand to buy JUST ONE lathe and not something I will have to upgrade from in a year. My question is what is the minimum I need to buy with the 3520B to start turning spindles and bowls. I already have the basic set of turning tools so what I am asking about is lathe accessories that do not come with the lathe. For example I bought a Powermatic table saw and it did not include a blade. Had I not had blades on hand I would have had to make a trip to buy a blade. Does the 3520B come with all the basic things I need to start turning as soon as I put it together without having to buy additional toys just to get started? I looked at one package in Osolink (1352001 - Powermatic 3520B Lathe List Price $2,799.00) they have the same lathe with The 3520B value package 1352002 comes with the following: 1352001 Powermatic 3520B Lathe, 6294733 Remote Switch, 6294727B 18" Bed Extension with Tool Rest Assembly for 3520B, 6294740 Right Hand Tool Rest (Inside), DVD Lathe by Nick Cook for $3,099. Are the accessories worth the additional $300 and do I need them? If I don�t buy them now will I in a month be making another purchase because I out-grew the basic stuff? Thanks, Eugene.
Re:Powermatic 3520
>John Here's my 3520a. I bought the 18" extension. I positioned it differently than most by putting it on the motor side. I don't use it often so I wanted it out of the way most of the time. When I need it I simply slide the headstock toward that end. I have the remote switch. Idon't use it much but when you are turning something big it is really nice to have the switch where you can reach it without getting in the line of fire.
I would buy a smaller tool rest. It comes with a 12 or 16". Too large for some work. You might also consider getting a chuck. You don't need one because it comes with a good faceplate but they sure are nice. I bought the Vicmarc 120 chuck.
Re:Powermatic 3520
John Mcalevey
>John, I already have a 3520A, a Stronghold chuck, remote switch etc. and have been exploring the possibility of mounting the 3520B extension outboard and lower to occasionally turrn larger bowls or platters. From all that I have read (TheAAW site has a lot of information on the 3520 A and B.) I might be able to turn something up to 40" in diameter. Much larger than I can see myself ever wanting to turn. The only problem I now see is turning a larger diameter piece of wood without the support of a tailstock. BTW, your picture of the 18" extension is the first time I have seen it. It looks very well designed. JM
Re:Powermatic 3520
>The extension is quite heavy and solid. In fact it's so heavy it's hard to install by yourself. I have also looked at the possibility of lowering the extension. I thought I would look at the new attachment for the 2035B before I do it. They did cast flat areas in the new models legs to accept the extension. I have a machinist in town that has a huge milling machine. I thought I might see how much he would charge to mill and drill the area for me. Since this doesn't have to be a super precise I don't think it would matter a lot, I just like to do things right if I can.
Re:Powermatic 3520
Gerry Meekins
>John,
Powermatic was kind enough to put the lower mounting holes for the extension on both legs. Now if you were to find someone with a new 3520b maybe you could sweet talk them into swapping a leg with you.. May save some money as opposed to going to a machine shop.
Just a thought..
Gerry
Re:Powermatic 3520
Bob Fawcett
>When it is lower, it should give about 30" swing. I don't have mine yet so I can't give an exact measurement.
I don't thin there are riser blocks available, but I doubt you would need them.
Bob Fawcett
>Eugene,
I recently bought the value package. You don't "need' them, but you will probably want them. It is good value as well. The extras if purchased outside the package would be a lot more.
You can turn with the lathe right out of the crate. You will probably want to add a good chuck. Any other items would be dictated by what you turn.
