Powermatic 3520
Allen Neighbors
>Is the 3520B reversible?
Allen
Powermatic 3520
Allen Neighbors
Allen
Re: Powermatic 3520
Ed Karch
>Yep and the head will slide down to the end to make a dandy bowl lathe.
Re: Powermatic 3520
Bob Fawcett
>And the short bed extension will attach to the leg and give about another 8-10 inches of swing.
You can also get a tool rest extension with the bed extension to bring the rest back to center height.
Re: Powermatic 3520
Rick Davenport
>And it has an indexer (the 3520a did not).
(that's supposed to be important, though I've never had occasion to use it)
Rick
Re: Thanks, Friends, but now
Allen Neighbors
>you give me cause to ask some more questions.
Bob, is that short bed extension the one that is 18"? I suppose it goes on the tail end of the lathe, since the motor would interfere...
Does anyone know what is entailed in setting up a 3 Phase system? and Is it worth the extra money to do all that, or is it just as economical to run it on single phase? It's not hard on the lathe to run it single phase, is it? Will single phase affect the power of the 2 hp motor?
Sorry for the seeming stupid questions, but I'm clueless.
I want the Oneway 1640 so bad I can taste it, but I'm thinking that I can get by a lot cheaper, and still do all the Oneway will do, with something else. Trying to be practical, I guess.
Thanks,
Allen
Blanked up another 30 feet of 18" diameter Bois d'Arc today.
I'm pooped.
3 ph is not a problem
TDaniel
>Either of these machines will convert single phase to 3 phase internally. A 15 amp 220 volt single phase supply is all that is needed.
Re: Powermatic 3520
>Rick I use indexing to lock the lathe in place for power sanding natural edge bowls with the lathe off. You can lock it just where you need it. Of course I do other advanced things with indexing but locking it for hand sanding has been the most useful.
Rick Davenport
>Yes, the extension goes on the tail end of the lathe and you slide the headstock down to that end.
I haven't bought the extension but I am amazed at how often I slide that headstock around to get into a better position to hollow out my bowls.
Single phase works just fine, the inverter is already mounted on the unit so all you have to do is run the appropriate single phase power. If I can do it, anyone can!
I've had my 3520b for about four months now and I absolutely love it.
For the price, I just don't think there is anything out there that compares.
Take the money you save and get all those gouges and gizmos you want too.
Just one rookie's opinion.
Rick
LT
>I agree with Rick. For the money, I don'y think anything else comes close. I've had my 3520B since February and would highly recommend it. Smooth, quiet, powerful and with 20" of swing and a sliding headstock, I doubt I will ever outgrow it.
LT
Keith Tompkins
>Allen, the PM will do anything you could possibly ask of it...plus, you'll be able to afford lots more tools. :)
>I turned my headstock so the extension is on the motor side. This way the lathe doesn't take up any more room in my shop than it would normally with the motor sticking out. Since I only rarely use the lathe at this kind of extension it didn't seem practical to do it the other way. I have the 2035A and I'm thinking about drilling the legs to accept the new Bowl extension that the 2035B is capable of handling.
I've turned on a lot of lathes and still think this is the best buy out there. Oneway's and Stubby are nicer but cost a whole lot more. I feel this lathe will last me a very long time and do anything I ask of it.
robo hippy
>I've had the 3520A for 6 plus years. I love it, but haven't turned on anything of similar size to compare it with. I some times wish I had a dedicated bowl lathe and keep the PM for other things. The Serious Lathe looks very nice, and is the same price as the Oneway, but they don't make a short bed model. I have worn out one set of headstock bearings (chainsawn blanks without the tailstock). It is the best deal in it's price range.
robo hippy
Rick Allen
>I feel for you Allen. You want the Oneway? The PM is a terrific lathe, but how is that lathe going to feel knowing it was second choice (;~>)
Actually, the One-way 1640 does not
TDaniel
>cost that much more. In the past I have said the PM3520 was the most lathe you could get for your money but after turning on the One-way 1640 I would gladly pay the difference. The optional outboard bed gives you the capacity to turn to 24" diameter which covers almost anything you would want to turn. Why do I like the One-way better? Here is a list:
#3 MT tailstock grips better than a #2MT which is important when drilling
The toolrest and banjo alone is worth the difference in price
Fit and finish are much better
Adjustable height
Higher resale value
Better after the sale service and super nice people to deal with (no automated switchboard)
They don't have to travel the high seas to get here. :)
Bob Fawcett
>Allen,
Yes the 18" extension. You can mount it on either end of the bed, or either leg. Not sure why you would want to at the headstock end, but I suppose you could get left hand thread stuff for the other end of the spindle.
The speed controller is an inverter drive. It takes single or 3 phase input no problem. As Terry says below not an issue. I don't believe that it will affect the power either.
Not trying to talk you out of the oneway, but check this:
http://www.osolnikmachinery.com/index.asp?PageAction=VIEWPROD&ProdID=11&HS=1
both lines above are the url. You probably have to reassemble them.
Re: Actually, the One-way 1640 does not
Bob Fawcett
>"#3 MT tailstock grips better than a #2MT which is important when drilling"
You can't get a #3 with the PM.
"The toolrest and banjo alone is worth the difference in price "
The toolrest and banjo is very nice. The 3520B has a redesigned banjo which I think is better than the 3520A - Oneway still wins.
"Fit and finish are much better "
Oneway wins, but the PM is no slouch. Fit and finish better than Jet.
"Adjustable height "
The PM has leveler feet that give a very small range. The height is 45" which should work for Allen.
"Higher resale value "
higher cost too.
"Better after the sale service and super nice people to deal with (no automated switchboard) "
Hope I don't need to find out a lot about this. :-)
"They don't have to travel the high seas to get here. :) "
True
Oneway is the better machine if price is no object. The PM is what I could afford and for the money is great value.
Oneway has48 position indexing spindle
Eddie Pacheco, San Jose, Ca.
>Uh, I don't have either lathe yet, and I was focusing on the 3520 until I noticed it didn't have an indexing spindle. I have this on my old Atlas lathe and I really like the feature. I've only used indexing a few times, but I really appreciate it.
TD's favorable comments, shortly after setting up a 1640 in his shop, have me saving some additional pennies to get the Oneway.
Re: Oneway has48 position indexing spindle
Rick Davenport
>The 3520b has an indexing spindle
The 3520a does not
Rick
