Terry Daniel and sandpaper
Russ Fairfield
>TD has been an advocate of the Norton 3X sandpaper. I finally tried it this past weekend. It is every bit as good as he said it was. Maybe even better.
Re: Terry Daniel and sandpaper
Devon Palmer
>I just bought my second pack of 20 (80/120), seems like the wood just flies off. My only complaint would be that the 80 is almost TOO good and leaves some seriously deep scratches, so, I avoid it as much as possible unless there's just no better way (aside from toolwork).
Jerry Hall
>I have been using 3X also on my homemade twist lock sanding pads, one for each grit. Roloc pads, with foam from a sleeping pad hot glued on, and then soft leather. The 3X paper is slapped on with 3M spray adhesive. The flexible paper on the leather, cut a bit oversize, cuts and conforms very well. This allows me to stock only one type of paper for a variety of uses. Sometimes the paper sticks a little too well and some is left behind, but that is not a big problem. This method was written up in the AAW journal a year of so ago, but for cheap paper which did not work well for me.
>Russ I've been playing with the 3X along with some eagle brand abrasive. I love the 3X and just ordered 20 sheets of each grit. It folds well for hand sanding difficult places. I personally think it last more than 3 times my regular brands of sandpaper. That stuff just keeps on cutting. The Eagle brand abrasive also cuts very cleanly but the backing doesn't last as long and the Norton.
David Galloway
>I think I know the answer but the Norton 3x does not come with a hook and loop backing does it? I would love to use Russ' method of cutting up squares for power sanding.
David Galloway
>Today at Highland Hardware, I found the Norton 3X in hook and loop but for a 5" orbital sander. I would imagine that they will bring it out in other sizes.
