thoughts on burning crazy?
Bob Fawcett
>I have been following the thoughts on burning pens that have followed Molly's demo at the "Gathering".
I wonder if you couldn't convert a soldering station to do this?
I have the Weller WES51 solder station. I found one site that sells this for $89.
http://www.all-spec.com/1/viewitem/WES51/ALLSPEC/prodinfo/
This is a temperature controlled station with a range of 350-850 degrees. I usually set it to 650 for soldering. Is that hot enough for burning?
The tips are easily replaceable and not expensive. The connecting end is also hollow. Seems you could drill one to accept the top portion of your copper nail. Solder it in even.
They usually have about 50 watts power which seems to be about what the dedicated burners have.
I think I will order some spare tips and try this.
Anyone else tried already?
Re: thoughts on burning crazy?
Eddie Pacheco, San Jose, Ca.
>I tried this with a similiar model Weller soldering station and I had lousy results. The wood drew away the heat so I had a bunch of dark and light spots on a short line I was trying to burn. Also the real hazard and drawback is the distance of the cool handle fron the worktip. It's great for soldering but bad for "drawing" or even making initials. Adding a short length of nail wouldn't be much of a help. I'm afraid we're just going to have to get one of them burner setups.
Bob Fawcett
>Thanks Eddie,
Maybe it wasn't such a good idea after all.
Ken Grunke from SW WI
>The typical soldering iron with the handle too far back from the tip makes for difficult control when drawing and signing, but that shouldn't make any difference for a brand which is only pushed straight down. I'd say it's worth a try, with the copper nails that Molly uses if you can get a good fit with the nail on the iron's end. Only one way to find out!
