Walnut oil question
Walnut oil question
Walnut oil question
>I just made a bowl of Bradford Pear. Want to put a walnut oil finish on it. Bought some at Kroger's for the purpose. Can someone tell me the way you do it. How many coats? How long to let them dry or soak? Do you buff? What about for a working bowl?
Re: Walnut oil question
Barbara Gill, Remlik VA
>Barry, it seems as if I have read that the walnut oil sold in the grocery store may not dry. Don't use it until someone who knows gives you good advice.
Bill Hale / Woodspinner
>I use walnut oil on a regular basis.
I make a wax using about 50 50 walnut oil and bees wax for the second coat.
I put the first coat on on the lathe and wet sand with 600 grit. Wipe it down to clean and let it dry a day or so. Do a second coat using the mix let dry and buff out.
It will produce a soft satain finish not much sheen.
Good turning and be safe
Bill in Casa Grande, AZ.
Rick Davenport
>I do what Bill does too.
If you are lazy like me, you can get Mahoney's walnut oil and his mix of walnut oil and wax at Craft Supplies.
I like the semi-satin finish, the fact that it is food safe and the nice smell.
Rick
Gil Jones on Lake Seminole GA.
>Try this site; they seem fairly well versed on the subject of oil finishing. http://www.navaching.com/shaku/oil.html
robo hippy
>Store brought walnut oil will cure just fine. The difference between it and Mike Mahoney's stuff, is that the salad oil is pressed, and Mike's is distilled. The distilling breaks down the protiens which can cause allergic reactions. I don't know if the pressed oil, after it is cured can cause reaction or not. I just apply a table spoon or so to each of two grey synthetic steel wool pads, and apply at slow speed. It will soak in fairly fast. Some woods (softer and open grained) will soak up a lot more oil. I turn the speed up and apply some pressure to build up a little heat. If you turn up the speed too soon, you will have racing stripes on the walls, lathe, and you. Next I put a beeswax stick to the bowl, then under medium speed, I apply my hands to heat and melt the beeswax. It doesn't take much pressure. I hit it again with the pads, barely hit it with a rag, then remove. Any surface oil will soak in.
robo hippy
Mike Schwing from Md.
>Barry I know you said you want to use walnut oil, so I won't try to talk you out of it. I would caution you that it is extremely yellow in color, and will definitely alter the color of bradford pear, which can have beautiful shaded of pinks and creams in it, and is light colored to begin with. It is a good finish, however, will harden as it dries, and is easy to reapply. The other replies have already gone over how to use it sufficiently that they don't bear repeating by me.
>What Mike says is true. Some "walnut" oils from the grocery store have not much more walnut in them than some "tung" oils have real tung oil in them. The adulterants WILL NOT harden. Read the label. If you find any ingredient obfuscation, put it back and go elsewhere. I know Loriva will harden. I treat it like a Danish oil, wipe it on, let it soak in and briskly rub it in, and let it "do its thing."
Alternately, if I am impatient, I apply it with Shellac (usually Zinnser SealCoat) in the manner of a French Polish.
Thanks, and one more thing....
>Thanks to everyone. As I mentioned I bought this at Kroger's. (Does everyone have Kroger's? How big a chain are they?) It is La Tourangelle brand and was a half liter for about $7. Says it is roasted walnut oil. Also says it is 100% walnut oil. It does yellow the wood, but in this case, I did not mind. This piece of pear was aged a bit and did not have the creams and pinks. So far I like what I see, Except that I apparently have gone blind and this stuff really brings out the sanding scratches. I went back and touched up my sanding and the finish is forgiving enough that it blends nicely, not making me remove it all and start all over. Pleasant faint English walnut smell, too.
Re: Thanks, and one more thing....
David Galloway
>Kroger is a large chain...we have them throughout Georgia.
As for walnut oil, I really like it. I particularly like Mahoney's. YOu might write him at his site as to why it is preferabe to the supermarket type.
DAG
