Ambrosia Bowl
Ambrosia Bowl
Ambrosia Bowl
Steve in NC
>Here is a photo of my latest work. Comments and suggestions please.
(Still working on the photography though)
Ambrosia Maple
Approx 12" Diameter and 3.5" High
Finish - 3 coats Tung oil knocked down to satin finish
Re: Ambrosia Bowl
Re: Ambrosia Bowl
Allen Neighbors
>Steve, I like the bowl, and the interesting, coved, shape of the outside trim. I also like the undercut rim. The foot is wide enough for a utility bowl, but I think someone will probably tell you it's too wide for art.
Being Ambrosia, this isn't for food use, is it?
Allen
Maker of yellow mulch, today.
Re: Ambrosia Bowl
Re: Ambrosia and foodl
Steve in NC
>Allen
Thanks for you comments. I have been trying to find a shape or feature to call mine. Not there yet but I keep trying. I like to do undercut rims though, I think it adds a bit of interest.
I have never heard of not using ambrosia maple for food. Is there a problem with it. The wood is sealed with three coats of Watco. Does the beetle leave a harmful residue.
Thanks again for your comments.
Steve
Re: Ambrosia Bowl
Re: Ambrosia Bowl
Glenn Hodges
>Steve that wood is so nice. I like your rim treatment.
Nashville, GA
Re: Ambrosia Bowl
Re: The worm leaves holes that
Allen Neighbors
>could house some rancid stuff, if used for foodstuffs. I would think it might be rather hard to fill those tiny holes... but maybe not. My Ambrosia bowl has too many holes, and I don't have enough time to fill alll of them.
Anyway that's what I was talking about. I've heard that it's not good to use a bowl for food, if it has any inclusions that would be hard or impossible to clean.
Allen
Making Bois d'Arc bowl blanks in Texas today.
Re: Ambrosia Bowl
Steve in NC
>Allen
Thanks for the response. You make a good point. I did put a drop of CA in each hole on the inside. This was a gift and I did put instructions with it that if it was used for food that it it only be dry food (not for salad type food). I really like turning ambrosia maple (there is a great source here in NC)so given this new info, I will be sure to either fill the holes or not use it for food.
Steve
Re: Ambrosia Bowl
Re: Ambrosia Bowl
Steve in NC
>Glen
Thanks for your comments. The cove on the rim resulted from a post here that suggested to try to avoid flat surfaces.
Steve
