salad oil question
salad oil question
salad oil question
Claudia Hayward
>I know that someplace there has been some discussion of salad oil as a finish (I know there are lots of food safe finishes but I want something other than mineral oil that I can suggest to customers that is readily available in a grocery store). The problem is that some salad oils are more prone than others to go rancid over a period of time. Which is the best oil to use - canola, sunflower, safflower, olive or ???
Re: salad oil question
Steve Lewis
>Mineral Oil works fine but Walnut oil is better but hard to find. Check at a Health Food store if you have one.
robo hippy
>I usse walnut oil on mine, which is available at most of the larger grocery stores. The nut oils will cure and harden eventually, which the vegetable oils will not do. Some people use vegetable oils exclusively. The problem of going rancid is (as I was told) incomplete oxidation, some times it happens, other times it doesn't. What this translates to is don't let oil and foods sit in the bowl over night, clean it out after you are done using it. Don't store a stack of bowls in a closed space for a long time, wood needs to breathe. Re oil as needed. I have an ash bowl that I take to the shows that I do, and have had it for 5 plus years. I wash it and dry it after each use. I have never oiled it since day one. It was very white when new, and is now a beautiful amber color. I have eaten pasta, pizza, salads, Mexican, Afghan, sushi, barbque, stir fry, ice cream, soup, cheese cake, and generally anything that will fit into the bowl. Eventually there will be some build up of oils in the bowl, and this is when you can use soap and water, or table salt with lemon juice or a bit of water. I lately heard that vinegar will also help to disinfect wood surfaces. Just about any oil will work, just wipe off the excess, and when there is some build up, wash it off.
robo hippy
>I just bought some Walnut oil from Kroger's for this purpose. Just put on the first bowl I have done this way. They had it in the "up-scale" or imported food section or what ever along with several other oils. It is made in the "French" style, whatever that is. Thicker than sunflower or canola. My only concern is for people that have nut allergies. Wonder if anyone would be affected after it cures?
Re: Claudia, Pure, Odorless
Allen Neighbors
>Olive Oil, mixed with beeswax is about the best I've ever found. I've used mineral oil, but people shy away when they know that was used. The following is an information sheet that I hand out with every 'utility' bowl:
To keep your bowl like new:
After using the bowl for food items, do not let it stand for a long time. Wash it with warm, soapy water, rinse well, and towel dry. Let it set for a few minutes to air-dry some more, then put a teaspoon of pure, odorless olive oil into the bowl, and smear it around with your fingers. Let it set for about 10 to 15 minutes. Wipe out the remaining oil, and it is ready for use again... just wipe it with a clean paper towel and use it.
To season your bowl after it has not been used for a month or so:
Sometimes after sitting for a period of time, some grains of the wood may raise a little, causing some rough areas to exist. If there are some rough spots, smooth them out with #0000 steel wool. Wipe it out. Pour a couple of spoons of pure, odorless, olive oil into the bowl, and add half a spoon of salt. Be gentle: Scour the inside with a paper towel, using the salt and oil mixture to purify and clean the inside. Wipe it clean and dry. Let it set for a half hour or so, and then put in another teaspoon of the oil, and rub it around with your fingers. Let it set for 10 to 15 minutes, and then wipe out the excess oil. It's now ready to be used.
NOTE: Mineral Oil can be used as a substitute. DO NOT USE extra-virgin olive oil, or any type of vegetable oil... they will become rancid; Pure, odorless olive oil will not.
Hope this helps you.
Allen
Maker of yellow mulch... today.
Claudia Hayward
>Thanks everyone - lots of good info there!!
Russ Fairfield
>Is the best source on finishes I know.
From his advice I've tried hazelnut oil, and walnut oil, both available at the health food stores around here, the wlnut oil is about 1/3 of the price of hazelnut oil, so it became the general use oil in my turnings, it is great to pop up grain, and finishes can be applied right on top of it even wet. I does not go rancid and it hardens.
A lot more info in Russ's dvd...
Jorge
