50/50 glue soak question
George Van in WI
>I have a 16� x 7�, 1 �� wall thickness, spalted hard maple bowl roughed that may or may not survive with the aid of your 50/50 glue soak but with the color I think a try is called for. I am wondering if I would be better off trying to dry it for a few months and then soak hoping to absorb more glue, or do you think it would do just as well now while it is still wet?
Re: 50/50 glue soak question
Wally Dickerman in Arizona
>George, I received you email...however, my email has been doing strange things so I couldn't send an answer.
I haven't experimented with how wet/dry the pieces were when I've done a glue soak. I think that they've always been at least semi-dry. I suggest that you dry the piece for awhile than re-turn it so that the walls aren't quite so thick before you do a glue soak. Be aware however, that it'll warp after the soak. How much depends on the wood and how it was cut from the log.
16 inches? that's going to take a lot of glue.
Wally
Wally
George Van in WI
>Thanks Wally. I will do as you say; I have it in a paper feed sack and will dry it slowly before returning it and then the soak. I plan to soak in a plastic bag to minimize some of the glue waste but as you say it will still soak a lot!
