Jordan hollowing tools
Bob Conrad
>Hello
Is anybody using the Jordan hollowing tools, I would appreciate
any comments pro or con.
Thanks in advance. Bob
Bob Conrad
>Hello
Re: Jordan hollowing tools
>Bob I've been using a homemade version of the same thing ever since I first saw John using his. I will probably buy one of the curved ones shortly because it's just plain ole better than my curved one. I like the shape. The fit and finish of John's tools are right on and I've always been a fan of the 3/16" cutter. It can be aggressive if you want but you can remove the tiniest sliver as well. They are easy to sharpen and inexpensive to replace if you need to. John's even added a tip sharpening jig to his line. They are so easy to sharpen by hand but John said he had so many requests for a jig that he designed one and now sells it.
I'm not a huge fan of his handle. I have arthritis that acts up occsionally in my right wrist and the angle of John's handle is just wrong for me. It is certainly well built and probably works well for most everyone else. I certainly would recommend trying it.
georgetroy
>Pro. I have the complete set and used them for roughing and bringing to an almost finish. The hook is just about right. I strongly suggest you get his special holder for grinding the small tips. Because I have arthritis, I have also put outrigger rods on these tools by BCT. John's handles are also very nice, with just the right weight and length. GT
e
>I enjoy using John's small and large hollowing tools and have been for years -- the large set has a slim nose which makes it easy to get into smaller openings. The tips are easily removed for sharpening or replacement.
they are obviously designed by someone who uses them!
additionally, his small set is a real work-horse -- i have other small hookers but always pickup johns.
lastly, john and Vickie are great people to do business with!
Gary Evans Tallassee, TN
>e,
What's all this about hookers and johns? 8^]
Bob,
I've not used John's tools, but I have helped sell them a couple of times. I think they are well designed and well constructed.
Ruth Niles sells them if you choose to buy somewhere besides the source.
Gary
eliot
>I started with the Dennis Stewart system and still use it from time to time,but I found that the disk and bolt that hold the cutting tip was somewhat big and cumbersome. (But it works O.K.) I went ahead and purchased a set of the Jordan tools (actually just the two curved ones), They work just fine; you really can't go wrong with them. And they get into smaller openings, which is what I was after. I still sometimes use the Stewart arm brace, though. I can't comment on Jordan's handle. Also the particular restraining system I use for hollowing large vessels (Keith Clark's Spin Doctor set-up) readily takes Jordan tools.
JamieDonaldson
>I learned hollowing from David Ellsworth in 1990 and have used his style tools which I made, but I also studied with JJ, and his tools are the real deal. I have made several versions of my own over the years, but JJ's are my favorites and fit in the Jamieson D handle or the Stewart(now Sorby) handle to reduce the torque of hollowing without a boring stabilizer.
