My Attempt
My Attempt
My Attempt
Barbara Gill
>I was taken with the home made handles Molly had for her coils and other self made tips. One was made per Graeme Priddle; it was simplicity at its finest. The other was more refined but way over priced. On the way home from the Gathering I started thinking about how I would make one using both examples. This is what I came up with.
Re: My Attempt
Picture #2
Barbara Gill
Re: My Attempt
Size: 6 1/4" Long
Barbara Gill
Re: My Attempt
Good Grief!
Barbara Gill, Remlik VA
>I just re-read what I wrote. I didn't mean to imply that Molly was selling them and they were over-priced. She showed us one she had bough; it was over-priced.
Re: My Attempt
Re: Good Grief!
Jim Shaver Oakville, Ont.
>Hi Barbara,
I didn't read it that way, but I know we know the character of Molly well, I think it takes a special person to open up their process and show us in detail how they do things...that is what makes this community special!
It was also considerate for you to make this post to clear up what you thought was potentially information that could be misunderstood.
Take care,
Jim
Re: My Attempt
Re: Good Grief!
Gil Jones on Lake Seminole GA.
>Barbara,
I did not take your post that way either, and your burning pen looks great! Now all you need is Nichrome wire and copper nails (and a powersupply/controller). Luck...
Re: My Attempt
Re: My Attempt
Carole Valentine
>Looks like that will work just fine, Barb. I didn't get the nails in the mail today...hope tomorrow.
Re: My Attempt
Re: My Attempt
Eddie Pacheco, San Jose, Ca.
>Hello Barbara,
Will the plastic connector that you are using for securing the tip stand up to the heat? Do the ends of the nichrome wire connect to the white terminal block? I have no experience with burners, but I have seen the plastice bodies of these connectors fail from excessive heat due to current.
Re: My Attempt
Re: My Attempt
Molly Winton
>They'll eventually melt a bit, but this method was designed by Graeme to be more of a temporary pen, rather than one that will last long. I had some char build up that eventually interfered with the current and the pen failed, but Gil Jones figured it out for me and we cleaned out the build up. It works fine now.
Very cool Barb. I haven't had a chance to make up the pen you sent me, but when I have a chance I'll let you know how I like it. Thanks a bunch!
Re: My Attempt
Yeah, What She Said. :-)
>You are welcome Molly. I figure if the connector fails it can be carefully sawn off with a bandsaw and a new one glued in place. The handle didn't take very long to make.
I didn't complete yours because I thought you might not want the connector where I would glue it.
Re: My Attempt
Thanks
Re: My Attempt
Re: Yeah, What She Said. :-)
Norm Smith in Nova Scotia
>Barb, That looks great. When everything is complete how about posting a picture with step by step instructions.
Norm
Re: My Attempt
>All I did was take a 3/4" board and cut two pieces the length I wanted so when they were glued up it would be about square. I routed a channel in each side before gluing them together (that was easier than trying to drill through the thing).
Then I just put the glued up block on the lathe and turned a handle which felt comfortable,leaving the top part where the wire connection large enough to work. I held the turned handle in a clamp for safety and carefully sawed off the part of the handle that needed to be flat. I lightly sanded the cut edges and then glued the piece of Barrier Strip with CA glue.
Then just get a piece of lamp wire and run it through the handle and secure the bare wires as shown in the pic. I have not bought the piece that plugs into my burner but that piece goes on the other end. All of the how to instructions came from Molly's demo. Nothing I did was particularly original.
Re: My Attempt
Re: My Attempt
Jennifer@Indy.USA
>Barbara, it looks great! Nice job.
If you have it handy...could you give us the part number to that little do-hinky from Radio Shack? Thanks!
Jen
Re: My Attempt
There ya go using those technical terms again!
Molly Winton
Re: My Attempt
Re: My Attempt
Phil Joines Krum, Texas
>I donn't know who might stock them but if you can find some of the black phenolic barrier strips they would be less suseptable to heat.
Re: My Attempt
Believe It Or Not...
>I kept the number. It is 274-677. The part is called a 12-Position Barrier Strip. Of course Carole and I didn't know that when we went into a Radio Shack in Greensboro. We did however know what it looked like and could describe it and the usual function to the clerk who knew as little (maybe less) than we did. Finally someone who knew something opened the bottom drawer of a big display and there it was. I used a hacksaw to separate the blocks as they are used for the handles.
Re: My Attempt
McMaster-Carr has phenolic strips & nichrome wire
Craig Daymon
>Finally got McMaster-Carr page to load.
They have both phenolic barrier strips (terminal blocks) on page 700 and nichrome wire on page 3514.
Molly, McMaster lists the wires by diameter. What is the diameter of 20 gauge wire?
Thanks,
Craig
