Delta Speed Controller problems
Roger
>I have a Delta 46-755X 16� Variable Speed Lathe that started having speed control problems after about 2 months of use. When running the lathe at 3000 rpm then stopping and restarting (with the on and off buttons) it would spin up to about 2500 rpm and then rapidly slow down to about 3-400 rpm. Turning the speed control knob down to around 2500 and back up to 3000 rpm resulted in the proper speed. Delta sent a repair service out and replaced the speed controller. The new controller experiences the same problem when cycling the lathe on and off about two out of every ten times. Does any one have this same lathe, and have you experienced this problem. If so, how did you remedy the situation?
Thanks
Roger
Re: Delta Speed Controller problems
>I have had that lathe for over 2 years and have not had that problem so I may be of no help...sorry. The controller is a Baldor and is generally considered an excellent controller. Sorry you are having problems.
I'm not totally understanding... Are you starting and stopping your work using the power switch? Or are you just referring to a problem that occurs between work sessions?
Tommy
Roger
>Thomas,
The power switch is left on, I am starting and stopping the lathe with the "Run" and "Stop" buttons on the Speed Controller. This only occures at speed settings above about 2500 rpm.
Roger
>I gotcha. The only time my controller has ever "mis-behaved" is when the work was heavy and imbalanced. Other than that I haven't had it happen. Hope somebody else can shed light for you.
Tommy
Bob Fawcett
>I don't have one of these lathes.
Roger says you have a Baldor controller. They have an excellent reputation. I would think you could also contact Baldor for assistance.
Most of these controllers are programmable for a wide variety of other functions beyond what we usually use on a lathe. It may be that the controller just needs a slight program adjustment.
Fog Tanner
>I have ahd this lathe for the last four years, before it was the "X" model. I've only had two problems with the controller, one had to do with coring bowls and was a programming issue. Delta was very good, they sent a new controller to test, I changed it out and it cured the problem and they got the old one back.
The other problem has occured on both, it will sometimes quit when I push stop. The piece will freewheel and the braking is gone. I generally have to turn it off and own to cure that. I found that when that happens, if I take a shop vac and vacum the controller the problem goes away until the next time I get too much dust build up. If I keep the controller vacumed periodicly I don't get the problem. I've had the cover off before and can see where the dust can cause a problem across some of the lands.
Roger
>Bob,
I am not so sure that the controller is a Baldor, the name plate on the mounted on it states "Delta Electronics Made in Taiwan."
Roger
Bob Fawcett
>Sorry Roger,
They must have changed somewhere along the line. I am pretty sure it used to come that way.
Bill Hale / Woodspinner
>Roger
I have a friend that also has had several problems with the controller. I believe his lathe is about 1 1/2 years old. Delta admited yo him that they have had problems. I believe the problem was solved with the last controller, 6 months ago.
Hit Delta or your dealer for another controller and I would also try for a new motor. Let them know that you posted this on Wood Central for all to see and let them know you will post the results.
Let us all know the outcome.
Good turning and be safe
Bill in Casa Grande, AZ
