We value your privacy.
Craftsman lathes are not top-shelf to begin with; I can't think of a Craftsman lathe worth $ 400.00 to me.
Noise could be bad/shot bearings, but could also be other things, depending on how the speeds are changed. Does this have mechanical variable speed -- which would mean changing speed without stopping the lathe -- or a series of stepped pulleys? If the former, these Reeves drive knock-offs are pretty well known for wear around the sliding sheave hubs, causing a loose and noisy pulley. These can be replaced without a lot of heart- (or wallet)ache. It could also be minor; the shaft could be so caked with gunk (a technical term for dust and oil), that the pulley sheaves simply can't slide on the shaft to the proper position, resulting in a loose belt that makes a lot of noise.
If the speed is changed by stopping the lathe, and moving the belt from one size pulley to another, make sure its not loose, and just noisy because its allowing the belt to flop around. If it's not loose, but still noisy, stay away.
>you can get a Jet mini for less than $300. Use the other $100 to start a collection of tools. I got a 6 piece Sorby set from Woodcraft for $150 on sale. I haven't seen this particular set since, but it is worth watching for. You can get other quality tools for a little less.
>Must be a universal DC motor the way it sounds. You are wise to look the other way, unless it's free--a friend of mine has a Craftsman lathe with integral motor in the headstock and it's been nothing but trouble.
