epoxy goof...help please
ken chase
>I added some black artists chalk to slow drying epoxy careful to add a bit extra of the cure. The epoxy never completely hardened in the crack I filled with it. I'm in the sanding stage of my project and the epoxy keeps leeching above the surface of the crack. The filling is doughy and I could sure use some advice about solving the problem
Thanks
Re: epoxy goof...help please
Sean Troy
>I've been there before and put a few drops of thin CA glue on the epoxy and it worked fine. Sean
White vinegar, maybe
Craig Daymon
>White vinegar can be used to remove epoxy that has not fully cured, but I'm not certain it will work in this case. Probably won't hurt to try.
-Craig
Re: thanks for epoxy help
ken chase
