Veritas - Innovation in Tools
Pressure Washing Bark Off BLM Burls
Dick Gerard
>Anybody have any idea how much pressure to use to remove the outer layers of bark from BLM Burls to expose the "Spikes"? I have a few that have aged nicely and I'm getting real tired of the pick and scrape process of burl removal!!!!!!!!! I definietly know that the pressure used at do it yourself car washes is inadequate. All help appreciated as always.
Re: Pressure Washing Bark Off BLM Burls
Jerry from Lapel In.
>My washer puts out 3000psi and it works fine for taking the bark off.
Peter Teubel
>I only have a 1500 psi washer and its not powerful enough to remove bark.
Any tips?
Keith Newton
>I was wondering if any of you that claim to have success at this have any tips?
This time of the year, is the easiest time to remove the bark from a freshly cut tree, and I am sure that you may have better results trying to direct your stream in under the edge using the hydraulic pressure from underneath to lift the bark, rather than just using it to erode the total thickness away from the top.
