Gouge Grind for Inside Bowl Bottoms
David Propst, Valdese, NC
>I was looking tonight for some side grind gouge info for Allen Neighbors and found the pic below that I put together some time ago explaining the 80 degree gouge I use for deep bowl bottoms or for concave rim bowls. It has been discussed here before, but since I had this photo put together I thought I'd post it.
Alllen's initiation to the bowl gouge at the gathering was a sight to behold. He has been turning with Oland style tools for two years and when he started producing smmoth shavings with a gouge he looked like a kid on Christmas morning.
Below is the 60 degree gouge grind I usually use and the more blunt 80 degree grind. The blunt grind is used with the bevel rubbing and perpendicular to the surface, cutting just off either side of the tip. The swept back wings are not necessary, but that's the way the tool comes off when using the Varigrind. With a light touch the cut it makes produces very fine shavings and a very smooth surface.
For open bowls that allow me to follow the curve with a bevel rubbing cut I use my 60 degree gouge. The 80 degree gouge is a "specialty tool" that is quite nice when I need it.
Some folks can get the same result with scrapers, but I get better results with this tool. If someone gives me a better way I'll gladly regrind the 80 degree tool back to my regular grind. The less tools the better!
David
P.S. At the gathering there was much praise for the 40 degree grind promoted by Stuart Batty. I'll be giving it a try this week.
Re: Gouge Grind for Inside Bowl Bottoms
HarryB
>I took a course with David Ellsworth last May. He had a similar gouge for situations where the "Ellsworth Signature" gouge would not work. Not one for each student, just one to pass around as needed.
So you are in good company!
Jennifer@Indy.USA
>David thanks for the visuals. They are a great help to understanding. I'm looking at the diagram of the gouge in the bowl...and am wondering if the flute is really presented like the diagram shows? With it facing up?
Jen
Wally Dickerman in Arizona
>David, there is a way to use your 60 degree grind in the bottom of fairly deep bowls. When you are using the 60 deg. gouge in a conventional way down the inside of the bowl, and as you reach that point where the bevel isn't contacting the wood, just roll the flute up a little, drop the handle a bit, and push the tool away from you with the handle leading. You'll be rubbing the bevel very near the nose and it'll make a nice controlled cut. The handle won't come near the rim. If this isn't clear, let me know. I'm surprised at how few turners know about this cut.
Wally
>Hi Harry,
I took this gouge to my class with David last October at Arrowmont. On Saturday evening he was turning a concave cherry bowl while we were working on our assignments. He asked to borrow my 80 degree gouge and without even touching it up on the grinder, cut a 220 smooth surface accross the bottom of the bowl in one pass. Kind of humbling...
David
I'll give it a try!
>Hi Wally,
I think I understand. I'll try it ASAP and report back to you.
THANKS!
David
Dave Belser
>I must be doing something like this as I don't seem to have as much trouble tranisitioning to the bottom. I'll pay more attention next time and see if I can improve my technique.
Just to be clear, when you refer to a concave rim, you mean a bowl with a rim smaller than the largest side dia?
Hugh Widdup
>As Jim Shaver said in a previous post we had Jim Clewes in for a demonstration, He showed his grind on the bowl gouge for doing the inside of the bowls. He has a secondary grind on his bowl gouges to do this procedure, he takes a BG with appox. 60deg grind then grinds the secondary grind at approx. 80deg. the problem with the 80deg grind by itself is the "heel" can still rub the bottom but as a secondary grind, there is more clearance on the bottom of the bowl.
Clear as mud??
He does not use any numbers for the angles what ever works for you is his motto.
I saw Mike Mahoney at the Desert Roundup this year and he uses the same type of secondary grind as well...
I saw Mike
