Hollowing ?'s
Hollowing ?'s
Hollowing ?'s
Greg H. from Wisconsin
>I have been turning for a year now. I have done bowls, spindles, and more tops I can count. I'm interested in getting into hollowing?
I am looking at either the Don Derry rig or the John Jordan set up. Is anybody currently using either? Good or Bad?
I would like to do some hollow forms with some carving, but so much you lose the turning in a vessel. I have seen the Trent Bosch DVD which is very good. Is there any other DVD's that would be good to see?
Thanks for the advice,
Greg
Re: Hollowing ?'s
Re: Hollowing ?'s
>I use a homemade version of the John Jordan rig for hand holling. I use the same bars in my Jamieson captured bar hollowing rig. I like them because the cutters are very easy to sharpen and easy and cheap to replace.
Re: Hollowing ?'s
Steven Antonucci
Hollowing on the cheap...
steve antonucci
>Go to your local hardward store and get some cold rolled steel bar stock (about $4). you can make your own handheld tools for almost nothing in about an hour. turn your own handles and all you need is some tools steel for a bit.
I think there are articles if you need more info ...
Steve
Re: Hollowing ?'s
Re: Hollowing ?'s
Joe Flemig
>Greg,
I own an assortment of Jordan's tools and I own the Derry system too. Don's approach on hollowing is that the outside of the vessel is what is the art. Getting the guts out is just a chore. Using his system puts hollowing into the hands of beginners a lot faster than mastering a hand-held system.
Having said that, one size tool does not fit all. A lot depends on what you are making. I have no less than 12 or 13 hollowing systems which include well over 30 separate tools and or cutters. I use them all depanding on what I'm hollowing. For small Christmas ornaments, I use Packard or Kelton hollowers. For 4-6" vessels, I tend to use a different set of Keltons, the small Jordan or the Don Pencil Stinger. I have a couple of Sorby's and a homemade tool set in this range too. Up to about 10 or 11", I use the Derry system, larger Jordans, or a Stewart tool. Even larger, I use larger Jordans, Stewart, Sorby, Scorpion or Exocet.
Each tool has a range of capabilities so you need to pick what you want to do first and focus on that. As you expand your capabilites, you can add tools.
Joe Fleming - San Diego
