Sanding problem
Sanding problem
Sanding problem
ken chase
>I find the one and two inch velcro sanding discs won't stay on the holders very long. Even purchasing a new holder didn't help.
Is there a solution? Or and alternative method?
I have tried to minimise sanding but in some instances I
can not.
Thanks
Re: Sanding problem
Re: Sanding problem
Dave Belser
>Heat is your enemy! You may just be having problems with cheap hook and loop - but my experience is that whenever I'm trying to sand too hard they start falling off. This includes the glue that holds the hook material on the pad. I'm always tempted to work the sander harder than I should when I power sand - the fact is that sanding is much more efficient with a light touch.
This may not be your problem, but I find that if I go lightly the loop material on the back of the disks doesn't start separating until the disk is worn out.
I use the artisan disks from Craft Supplies USA:
http://www.woodturnerscatalog.com
- Dave
Re: Sanding problem
Lathe speed?
Dave Belser
>Just thought of another factor that can contribute to heat and failure of hook and loop. Are you sanding with the lathe running and if so at what speed?
My technique is to stop the lathe and check for end grain that needs to be sanded out. If needed I sand this out with power sander rocking the bowl back an forth using a light touch. Once the end grain is sanded clean I'll power-sand up thru the grits with the lathe running real slow 100 - 250 RPM.
If I'm hand sanding the lathe rarely turns faster than 500 RPM
- Dave
Re: Sanding problem
Re: Sanding problem
georgetroy
>Hi Ken,
In addition to the suggestions by others about sanding, I use inertia sanders in the 2" and 3" to reduce heat. I don't like the sanding discs that has the little tabs around the circle. They separate fast. Having good luck with the discs by
Steve Worcester
www.turningwood.com
Re: Sanding problem
Re: Sanding problem
>Ken, Our club buy disks and paper from Industrial Abrasives. I have uses some of the pads for several years and i probably bear down on them too hard. I find I tend to crush, over heat or just plain wear out the pads around the edges. I tend to sand on the edges more than the center of the disks. AS the pads wear out I find they won't "grab" around the edges because the hooks are worn. Then what tends to happen is the pads fly off because they don't hole around the edges and that's where the stress is. If I take the time to "bed" the disks better by sanding with the canter a little, they hold better, however, if the edges is worn and I put too much pressure on them, then they wrinkle and get pleated around the perimeter. My advice would be to get good disks and pads, bed the paper carefully and let it seat and sand lightly. I am in the process of buying a mandrel or pad for each grit so I won't have to change the paper between grits. I will change the mandrel in the drill.
PS, don't take this as a condemnation of Industrial Abrasives stuff. I like it, and think it works as well as I expected. Not affiliated, just a customer.
Re: Sanding problem
Re: Sanding problem
robo hippy
>What kind of sander do you use? I used to use the high speed drills (Sioux/Milwaukee) and have gone to the slow speed ones. I don't think that I have had many of the 3 inch discs fly off, except for some that had bad glue. The 2 inch ones will fly off, especially at high speeds (heat). I have found with the 1 inch discs, you use almost no pressure. Since they are so small, the psi is a lot higher with almost no pressure, which makes more heat. I do have one drill for each size of disc. I know one guy who has one drill for each grit. I buy bulk 12 inch wide rolls (special order) from Klingspoor. and punch my own discs. I had cutters made from pipe with 3, 2, and 1 inch ID, and had them reamed out a bit so that the discs are about 1/8 inch wider than the pads. I have noticed that I wear the outside of the disc out more on the inside of the bowl, and the center more on the outside. With the red, aluminum oxide discs, I keep the rubber stick handy to clean them, and get more use out of each disc.
robo hippy
Re: Sanding problem
Re: Sanding problem
adrien
>you might contact Bruce Hover at
http://www.thesandingglove.com/
the ceramic disks don't use velcro, but adhere with a fairly strong adhesive.....
Re: Sanding problem
Re: Sanding problem *LINK*
Charles Bjorgen
>Ken -- If you have a chance to view Disk One of Russ Fairfield's new DVD video set called 'Finishing Secrets," please do so. He addresses that very sanding pad problem you describe and offers several solutions to the problem. Below is a link to his web site that describes this video set.
Russ's Videos
Re: Sanding problem
Re: Sanding problem
Steve Worcester
>I agree that heat is the enemy, and heat can be a combo of speed and pressure. What starts to happen is the heat singes (melts) the velcro and the disks don't get enough grip.
Another problem is that if the disks or the velcro get too dusty, they won't grip.
1" is another story. I would only recommend that you use those with the lathe stopped because there is so little contact area on them they tend to spin off. Generally I recommend they only be used to clean up surface details. I don't post them on the website because people really need to be cautioned on the do's and don'ts and a little guidance on how to use them.
If you don't like the disks you are currently using, email me and I will send a sample of mine for you to try.
Steve Worcester
www.turningwood.com
