Grizzly 1019 BS
Grizzly 1019 BS
Grizzly 1019 BS
W.C. Turner
>Hi,
Recently, while cutting out bowl blanks, on my older Griz 1019 bandsaw, I smelled burning rubber. Upon closer inspection, I discovered the tire on the top wheel had slid partially off the wheel, and was rubbing the inside of the saw. Each time I put it back onto the wheel, same thing again.
Anybody else with this saw, or any knowledge of BandSaw's in general, have a suggestion for a solution? I don't think these tires were ever glued on the wheel. Maybe they have stretched over time?
Any help appreciated.
Thanks,
W.C.
Re: Grizzly 1019 BS
Re: Grizzly 1019 BS
Earl Kennedy
>Hi just go to a hard ware store or auto parts and buy the best contack cement.Auto place will call it trim cement probably.Just do like the instructions says for the strongest bond.I use drink cans cut cans and tape over wheel and then put tire on.Then pull the can pieces out and the tire will be glued right where it shoud be.You haft to keep the glue fron touching till you have the tire where you want it.You can't reposition it one it touches.Works for me.
Re: Grizzly 1019 BS
Re: Grizzly 1019 BS
>Probably stretched out. You may think about getting a new set of urethane tires. They work quite nicely and are relatively easy to install.
Re: Grizzly 1019 BS
I Have a Grizzly 1019 BS ...
Clem Wixted
>...that was made in 1983. Inherited it from my FIL.
Replaced the tires with rubber ones from Grizzley about 13 years ago and have rarely used the saw. Started using it last year and the tires blew on it again.
I decided to put an extension block on it and changed the tires to polyurethane. The tires take a little work to put on but no glue is needed. I hadn't used glue on the rubber tires either.
Also added a spring from Iturra and bandrollers as well. Now I need to start using it instead of the 14 inch BS that I have as a backup.
Clem
Re: Grizzly 1019 BS
Re: I Have a Grizzly 1019 BS ...
W.C. Turner
>Thanks for the response so far.
Funny thing. As I mentioned, I placed the tire back on several times, & each time came off. The last time musta worked some magic, cause when I tried it today, it appears that the tire is going to stay on.
Re: Grizzly 1019 BS
W.C. Turner
>Would double stick tape keep the tire in place, or would there be too much friction, & melt the tape?
Re: Grizzly 1019 BS
>I don't believe in glue or tape for this. A new tire (urethane or rubber) is probably the best answer. My $0.02.
