We value your privacy.
>Started "turning" my first Ambrosia Maple bowl yesterday, used a
piece of Maple which has a moisture content (using a Wagner pinless meter with a specific gravity setting of 55--I am guessing on the SG setting) of 9.1% MC. I roughed-out the shape yesterday, leaving the wall thick...it started off being 4" tall and 10" (OD) wide....and now is 4" x 9 1/2" (OD) and party hollowed-out...
1. Should I wait ??days/weeks/months, before finishing it?
2. Should I do it in stages?
3. Twice duing the turning, the Oneway Talon slipped when my Glaser
gouge got "caught"---how tight does one tighten the Talon?
If your moisture meter reads 9.1% on the outside of the bowl, it's very unlikely that it will be anywhere near that dry on the inside of a 10" x 5" chunk, so it might very well warp (or possibly crack).
I'd put it into a paper grocery bag right away (to avoid cracks), and if possible, weigh it on a postal scale or similar. You can take it out and weigh it every week or two, and see how it changes. When it stops losing weight, you can finish turn it. Now, to fess up, I never weigh my bowls, but I usually have a lot of rough-outs around, so I'm not usually in a hurry, and I just set it aside in a cardboard box for 4 - 6 - 12 - 18 months, or whatever. I usually rough out bowls in batches, and toss 4-6 in a box with some shavings, and set them aside. I do write the date on the bottom, or on the box, so I know its age when I need a bowl to finish.
If you have a properly sized and shaped tenon, you can squeeze it about as tight as you can manage with most woods. Real soft wood is an exception. Sometimes the shape of the tenon is the issue, which has to be just right for the jaws used. Bigger tenons aren't usually better ! For the #2 jaws (~2"), you probably want a tenon only about 2-1/4" or so, even though the chuck can go much larger. This allows for truing up the foot and gripping it later, after it has warped out of round. The further the chuck is opened, the less the grip (though the Oneway profile jaws are shaped to minimize that somewhat).
You also should turn a small flat rim on the base of the bowl for the tops of the chuck jaws to seat against. This adds a LOT of strength to the grip. Don't let the tenon touch the bottom of the jaws -- 3/8" is about right for the #2 profile jaws. The flat rim, and the tenon, are usually turned off later when the bowl is reversed to finish the bottom.
By now you should have the 2nd, 3rd, and 4th all roughed out, and ready to toss into that box !
>Phil, I use a digital kitchen scale when I'm trying to determine if a piece has "finished" drying. You can get one that will read to about 5lbs for around $25, its turned out to be a good investment. The meter reading of 9.1 sound like it's pretty dry already but a scale will let you watch the grams of water disappear each day. When the weight stabilizes for a few days you can finish the bowl.
This also assumes that your shop is relatively dry and stable. I also purchased a $15 inside/outside temp and humidity sensor. It has a min/max tracking feature that allows me to keep track of the humidity in my shop and the daily swing.
When I do a twice turned bowl, I rough them green and wait 4 months to a year (measure weight when finished roughing, mark it on the bowl, check the weight once a month till it stops changing). If I'm really concerned that the bowl might warp or just trying to control it, I'll turn the bowl close to final size and let it sit for a few more days (checking the weight) before finishing it.
>I tighten my Talon as tight as it will go but when the wrench stops turning with reasonable force that's it. Rather vague I know. You either got an extremely severe catch or the chuck was a little loose. As a rule Oneway jaws really hold well particularly if you have a tenon size near their almost closed size; just about all of my catches, not that I get that many ;), don't even knock the blank off true.
When tightening the chuck, tighten in one hole then rotate the chuck to the other key hole and tighten there and then go back to the first. Do this until all the obvious slack is out of the grip.
Make sure you create your tenon according to Oneway's instructions. Should be flat not dovetailed and there should be a true edge at the bottom of the tenon (the base of the bowl) for contact with the top of the jaws. As said by Brad, the tenon should not contact the bottom of the jaws.
If you have a softwood or punky tenon (good maple is not in this category) you can drizzle CA glue around the tenon and let it set to stiffen the wood if necessary.
>Thanks for the quick replies...I am glad that I posting my questions
here....I thought I could start on Thursday, wait a couple of days, and finish it off....Never thought it would take months ! Oh well, so much for making this for a Mother's Day Gift 2006...
I guess one last question, what should the MC be when it is completely dry? For my furniture, usually it is between 8%MC and
>I don't know when mothers day is (boy am I in trouble) but a couple of follow up points.
First, I agree with Brad, I'm not nearly as obsessive about weighing as my first response may have suggested. Having a scale allows you to get a much more accurate idea of what going on moisture wise with a piece.
Regarding the 9% MC you measured, that sounds pretty dry to me also but not "all the way there". I have a pin less Wagner meter also and have found it to be almost useless on bowls. The readings vary widely depending on how much of the sensor contacts the surface of the wood. Works great for flat stuff, but by the time I want to measure a bowl blank there isn't a flat enough place to check it. Also the thickness of the wood also effects the reading on the Wagner. Both of these problems mean I don't' use it on bowl blanks.
How thin is your current wall thickness? If you have a good dry place to keep the bowl for a week it may dry out enough - here is where weighing it daily can tell you a lot.
To me, there are really two main points to drying, avoiding checking and splitting and limiting warping. Check and splitting tends to happen early in the drying process when there is a great differential between the inside and outside of the wood. It sounds like your past this point and have a relatively dry piece. The second aspect is where you want to be sure the piece is evenly dry through out.
I've never tried it but some people use repeated microwaving and weighting to dry pieces quickly.
If I were in you position, I'd turn it close to final and weight and watch it. When it calms down finish it. All bowls will move and warp when finished the more skill you acquire the better you will be able to control this. My first large bowl went oval one me after a few weeks (not a lot but it bugged me - I'm a Virgo:) So I mounted it again and re-trued it as it was also a little thick walled. Now if you look closely you can see that the rim thickness varies where I trued it up.
Your mom will love the bowl no matter what you do!
>Thanks again! Yes, my wife will love it (I am a retired old man-my mother is long gone); my eldest son is very ill, so I was planning on turning the bowl and letting him finish it-and give
That's such a cool way to produce a very nice gift.
I would say that 9% is essentially all the way there, at least for here in VT where it's pretty humid. However, it probably isn't 9% way down deep in the wood. Was that MC figure from the outside of the bowl blank, or from the finished bowl ? My original comment was that a big 5" thick chunk of wood that's 9% on the surface, could be 20% in the middle of the blank.
Here's an easy test: put the bowl in a sealed plastic bag, keep it indoors where its warm, and wait overnight. Next day, open the bag, and turn it inside out. If there's any real moisture in there, the inside of the bag will be damp when you open it.
The bowl will probably warp somewhat because you've cut away a lot of wood, and this allows internal stresses in the wood to be released --> warping.
You could finish the bowl right now, without cracking in most cases, but it will probably still warp a little. You can turn to final thickness, add whatever little datails you want, and wet-sand the bowl with some sort of finishing oil. In other words, slather the thing with oil (I use Urethane Oil, but Watco, or some other polymerizing oil will be fine, and available locally), and sand it rather slowly on the lathe (so you don't wear ALL of it), wetting and re-wetting the abrasive paper or cloth with more oil. You can go all the way up to about 320 or 400 or so. (I would NEVER sand a bowl that is to be used beyond 400 -- just asking for it to look bad later, IMHO.) Then wipe off as much oil as you can, and allow it to dry overnight, or until the surface seems dry. You can then keep adding finishing oil about once per day, then wipe off, and allow the oil to harden between applications. Soak oil into any areas that look dryer than the rest. If any sanding marks show up, oil won't make them go away -- you'll need to very lightly sand some more -- you can wet sand by hand, too. I usually don't want a glossy finish on a utilitarian bowl, so I try to acheive a low-luster finish. After hardening for a few days, any spots that have gotten too glossy can be buffed lightly by hand with a real fine non-woven nylon abrasive pad (gray), or very fine steel wool. After this, a little buffing with paper towels gives a nice, mellow finish.
There are many turners who buff finishes by machine to a desired sheen, but you really ought to wait a few weeks, until the finish has completely cured for that. I also would not consider the bowl food safe for about 3 weeks after applying the oil finish.
That's just one possible route, since you're in a hurry. Mother's Day is the 14th, so you should be fine. If you still have moisture in the bowl, look for David Smith's denatured alcohol (DNA) soaking method by searching the archives, or read up on microwaving bowls -- both are fast ways to get to the finish line.
