What material to make molds
Phil Joines Krum, Tx
>I want to cast some poly resin �tools� to show the various grinds.
What�s a good material for the molds? I�d like to make them in one piece. I�d also like to be able to reuse the molds. Plaster of Paris would hold it�s shape but I don�t know how difficult removing the casts would be. It would be easy to remove them from RTV but how well does it keep it�s shape? Any other suggestions?
Re: What material to make molds
>Phil,
Molding plaster (different from "paris") is fine for single-use waste molds, but it doesn't have the structure for multi-use casting. What is usually done in your situation is a 2-part rubber mold which fits inside a more durable shell. There are several rubber options depending on what kind of resin you will be casting. I think most all of them will still require a mold separater, again tied to the casting resin being used. The rigid shell, which maintains the rubber's correct form, mentioned should be a more durable plaster such as Hydro-cal, unless you choose to go with a fiberglass shell. Your local library should have a number of illustrated books on how to make flexible molds.
Mark
Gary Evans Tallassee, TN
>Hi Phil,
My prototype engineer buddy uses a two part silicone to make his reusable molds. He makes a box with polycarb, aluminum sheet and packing tape to hold the mold when it is being filled. This makes it easy to remove the mold and separate it to get to the molded piece. Bear in mind that you will need to cut a channel through one surface to fill the mold and that you will need vents through the same surface wherever air is likely to collect in the molded piece. Got to get all the bubbles out.
If you are casting two part urethanes, you won't need any mold release to separate the mold from the casted part. In fact you won't want it if the part will be painted, but you will need it to keep the urethane from sticking to the polycarb and aluminum.
Bear in mind that all I know is what I've picked up the dozen or so times that I've helped him out. Injection molding is a whole education.
Gary
Re: What material to make molds *LINK*
Bill Kay
>Hi,
I have had great results using Ultracal to make molds for large model airplane parts. It is inexpensive and works well.
http://www.plaster.com/Ultracal.html
Thanks, ordered a gallon.
Jennifer@Indy.USA
>Hi Phil,
Are you using these as teaching devices? I can't remember who it was, but someone I saw giving a demo, or maybe on a video used a mock up of the tips of the tools by making them out of what was probably 4x4 pine posts. He just turned them round between centers to look like giant tools and then carved or sanded the grinds on the ends. He didn't make the full length of course. Just the cutting ends. It was a fantastic way to be able to show a crowd what he was talking about. Everyone could see the huge tool tips and grinds from way in the back.
Just a thought....it would be fairly easy and cheep too.
Jennifer
AAW Sharpening DVD
Mike Brazeau
>Jennifer - It was Bonnie Klein in the AAW Sharpening Video/DVD. Just received mine this week and had a look at it the other night. Bonnie did a great job on the Bowl Gouge and Scrapers and her wooden models clearly showed angles etc. Especially liked the way she did initial long grind on bowl gouge. I had looked at that video a couple of years ago, but really enjoyed the DVD on my 40" LCD TV. Easily worth the cost of membership and the rest is a bonus.
Mike
Don Evans
>Phil:
I don't have any personal experience to pass on to you, but Micro Mark sells material for casting purposes. They also have a small booklet devoted to the subject.
They carry everything from the plastics to low melt metals, it may be worth you taking a look at their site and also get the booklet.
www.micromark.com
Don
Re: AAW Sharpening DVD
Jennifer@Indy.USA
>Mike, is that where I saw it? I bet it's been at lest two years since I watched the video as well. I'll have to pop the DVD in and see what I missed the first time!
Jen
...are you going to Louiville?
Coming to Louisville
Mike Brazeau
>Hi Jen. Yes, this will be my first conference and really looking forward to it. My wife is coming along and we are going to try and take a few additional days vacation somewhere in the area. She says she is even going to sit in on demos! Most of all looking forward to finally meeting a lot of WC and Wow comrades.
Mike
Steve Worcester
>You can make the mother mold out of silicone or rtv and then pour resin or something like it to create the "positive" You generally need to spray the tool with a mold release and then the mold as well for the positives.
http://www.smooth-on.com/ has a wealth of products and knowledge and sell trial kits also. If you just want to do a small batch, I have the material here. You can come by and use some materials. (I do molds for my glass work, using my turnings for the original)
Steve Worcester
www.turningwood.com
Steve, Thanks for the offer.
Phil Joines Krum, Texas
>I didn't know you did glass.
I've ordered a gal of mold plaster, it should be here in a couple of days. I already have some poly resin for pens but haven't used any yet.
We are getting a lot of newby turners in our club and I can still remember how hard it can be to get a grind right if you don't have something to go by. I plan to make several sets for the club "library". If doing the casting doesn't take too much time I may make some for sale.
Re: Steve, Thanks for the offer.
Don Evans
>If you have some already, you can use Bostik TopCote (used for bare metal machine tops) as a mold release.
Don
Re: Coming to Louisville
Jennifer@Indy.USA
>Fantastic Mike! It will be a pleasure to finally meet you.
Jen
