We value your privacy.
>I have a newbie question. I cut a couple of sections off two trees I downed, and I want to make bowls from the wood, but not right away. What is the best way to keep the wood from checking til I can turn it? The pieces are about 12" dia X 30' long. Would putting them in plastic bags work?
>12 inches by 30 feet? You could certainly cut them up fully into ready blanks and coat in something like anchorseal BUT I suggest:
get them off the ground a bit (like roll them up onto bricks or 2X4s or whatever, trying to keep them from staying wet and rotting from the under side). Then, when you want some, cut a few inches off one end (to get rid of the checked/cracked parts; they shouldn't extend too deep) and then take the next nice section...continue until you've used it all.
For a week or so, until you get a free weekend, you can put them in plastic bags in the shade and in the coolest place you can find. I wouldn't do that for more than about 2 weeks, or you'll have quite a slimy mess.
For Cherry, you can also cut into billets (half-log sections, cut down the pith), and put them in a covered, shaded barrel and fill it with water. This will buy you some time with no special stuff. Veneer mills around here used to toss them in a pond until ready to use them.
The tried and true way, however, is to coat any cut surfaces with Anchorseal, and store them out of the sun, away from wind, and away from extreme heat. (Anchorseal and a few other similar end grain sealers are water based wax emulsions.)
Black Cherry doesn't spalt in any way that's appealing, so I wouldn't try for that. Some people like to cut it into usable sized blanks right away, but I don't, unless you are ready to use them right away. I suggest splitting (cutting) the logs along the pith (try to get pith centered along the cut line -- might mean one larger and one smaller half), and wax them with two coats of Anchorseal. In this way, the half-log sections can dry slowly, and as they shrink, they will usually not crack, but will form a crowned high area near the pith. Then you can cut off bowl-sized pieces as you can handle them -- waxing the new cut surface, of course.
