Indexing fixture (almost) and a ? for a machinist
Craig Daymon
>I was thinking of a turning project that will require an indexing attachment, which my 3520A doesn't have. I know there are inexpensive plans to make one, but the latest Enco catalog was sitting next to me and while flipping through I saw product #FR891-6020, a 36 point indexing fixture, which (somehow) will also index down to a single degree.
I figured I could rig it up at spindle center height on the tailstock end by building a platform for the bed ways and have a real nice indexing rig. I could also build a platform for the Jet mini and use it there as well.
Machinist question:
This is a 5C Index Spin Jig. I saw in the big Enco catalog an adapter for an R8 to #2 Morse taper. Does such a thing exist for a 5C? This would really make this work perfect for me.
Additional info for anyone interested in trying the same. The "FR" part of the catalog number is important to get the sale price of $41.95. What I bought is actually more than you need because it was packaged as the fixture and holder (which I thought was for mounting the fixture). The holder was a cut sheet metal rack for 5C collets to be used with the fixture. Unfortunately, I don't recall the sale catalog number for just the fixture, but the fixture alone was only about $32. (I might be able to adapt the collet rack for holding lathe tools.) If you want the collet set as well, the whole package was something like $169 in the sale flyer. (That was the big letter price.)
-Craig
Re: Indexing fixture (almost) and a ? for a machinist
Ken Grunke from SW WI
>Craig, I can't directly answer your question but if two places don't have the adapter you need it likely doesn't exist, or has to be custom made. Those places would be:
http://www.mscdirect.com/
or
http://www.mcmaster.com/
Gary Ljostad
>Craig, check out this one. For $19 you cant go wrong. I have been using this one on my 3520 with no problems. I found this when I was in AZ. for the Desert Woodturning Roundup. Hope this helps.
Very interesting...odd product line-up
Craig Daymon
>I'm thinking this was actually something made for an entirely different purpose, but the price is good. I've bought all the pieces for my more expensive rig, but I'm going to keep this in mind and might still order one up. I'll definitely pass it along to other 3520 owners I know.
Very odd that their only product in the woodworking section is indexing wheels.
Thanks,
Craig
>Thanks Gary I ordered an index plate and will let everyone know what I think when it comes in.
T.W. Fuller
>Hi Craig
In my 40 plus years as a machinist I have never seen an adapter to go from a 5C collet to a morse taper, that doesn't mean they don't exist just that I haven't seen one. What you can do however is purchase Enco part no:214-8704. This is a steel sleeve that will addapt your no:2 morse taper to a 1" straight shank. Then with the purchase of a 1" 5C collet, Enco part no: 230-4161 for your index you should be all set.
T.W. Fuller
Ouch! Better prices at Enco than MSC!
Craig Daymon
>TW, that's what I did, but I ordered up the parts from MSC because I couldn't find them on Enco. My collet was about $8.95 (as opposed to $3.99 on sale at Enco) and my straight socket was about $15.95 (as opposed to Enco's $14.95).
I think this rig is going to work well...if I can set it up right.
Thanks all,
Craig
Paul Coppinger
>I made an indexer for my 3520A using one of these Enco indexers by making a saddle platform over the motor and using a pvc endcap bolted to a collet that fits into the indexer(total cost about $40-50). The pvc was cut with a bandsaw so that a hose clamp would tighten around the lathe handwheel. To use, I place the indexer with collet/pvc attached, on the saddle platform, push the pvc coupler onto the handwheel and clamp....1 degree indexing, which is way too fine but I got it.
Hope this helps.
PAC
