what finish, little ash bowl
Mike Hamilton
>A question for those not on the road to Georgia.....
I have a simple, small ash bowl. It is off the lathe and completed, except the finish. It is sanded to 600 grit. I've only completed a couple bowls to date. This is the first non-cherry one. I have no spray equipment and generally prefer wipe on finishes for my flat work. I've tried shellac on my prior bowls and haven't been pleased.
Any thoughts on what I ought to try on this bowl that might fill pores and not add tons of yellow?
Thanks in advance,
Mike Hamilton
Re: what finish, little ash bowl
Greg Haugen
>Alot of my fellow turners from our club like the Wipe On Poly's. Minwax has one and General Finishes does also.
Hope it helps
Greg
Jim Shaver Oakville, Ont.
>Hi Mike,
That's great that you are turning now! I'm a basic bowl turner and my finish is simple. I some times depending on the wood apply an oil, Watco Danish oil ususally. I wipe on a few coats and let it dry for a day or so. I then rub it out with 0000 steel wool, some times a piece of brown paper from a shopping bag. I then use my Beall and use the Tripoli and Diamond bars then wax.
If I want a gloss finish I apply a few wipe on poly coats and buff.
It's my process, not perfect but it seems to work for me.
Post your work Mike!
Take care,
Jim
