Oneway 1640 plug
Jim Rutten
>Hello,
I talked to my electrician brother-in-law and he said there is more than one type of 220 plug. Can anyone tell me what the 1640 plug looks like? Is it like a dryer plug?
Thanks in advance for your help.
Oneway 1640 plug
Jim Rutten
>Hello,
Re: Oneway 1640 plug
Bill Howatt
>You'll probably get real answers from some owners but from the 1640 specs at the Oneway site: "A 9 foot power cord with a 15 Amp plug is standard.".
A 15A 220V plug is the same size as and looks like the standard 120V plug except the hot pins are both horizontal.
Bill
Brian McKearney
>Here's a pic of the plug that came on my 1640.
Brian
E Tabachek
>I believe that is the 220v, 20amp plug. I think there is a 220v, 15amp plug that has one horizontal and one vertical pin.
Surprised there is a plug
Craig Daymon
>I'm surprised it comes with a plug at all.
My JET cabinet saw, my Oneida Super Gorilla dust collector and my Powermatic 3520A didn't come with plugs.
I have twist lock plugs (P630) on all my 220 equipment. I guess it is nice that the 1640 comes with a plug, but if you don't have the right outlet it isn't going to help.
-Craig
Brad Vietje
>That's the 15A - 220; just wired one up yesterday, and have the other here on my desk. My Powermatic only draws 6.2 amps (from motor plate), but I don't know about the Oneway. I wired a 20 amp circuit, and the 20 amp recepticle will accept either 15 or 20 amp male plugs. You should not be able to plug a 20 amp male into a 15 amp circuit, but you can go the other way, plugging a 15 amp male into a 20 amp service.
Safe spinning,
Brad Vietje
phil in NJ
>The plug that comes with is an NEMA 6-20P I believe (at least it was on my Oneway 2436).
Bill Howatt
>No, that is the 220V 15A plug alright. The one with one horizontal and the other vertical is the 220V 20A plug. Note that the vertical pin is opposite to the vertical one on the 120V 20A plug - obviously a good idea.
Bill
Brian McKearney
>FWIW, I have my 1640 wired on a 220 20A circuit. I bought an outlet to fit the plug that came installed on it and just plugged it in and I was up and running.
Brian
