Dogwood
Dogwood
Paul Kramer
Dogwood
Paul Kramer
>Folks,
I've been lurking for a while here and looking at the beautiful work you all produce enviously. The question: I have been rewarded with a moderate quantity of fireplace length pieces of dogwood. It seems most if not all was branch wood (pith is way off center). Is this usable for turning? I was thinking I could get some chisel handles out of it and maybe if I'm really lucky a mallet head. Pipe dream? Or am I underestimating it's value completely? Wadya think?
Paul
Re: Dogwood
Keith Tompkins
Re: Dogwood
Keith Tompkins
>Hi Paul! Welcome aboard and glad you finally posted. Dogwood is dense and heavy....ideal stuff for turning.If you want to make handles from it, you'll need to rip it into oversize blanks, and seal the ends. Store it so air can circulate around it freely, "stickers" are traditionally used for this. If you leave it in log form, it will crack and split.
Use some for practice pieces: goblets, small boxes, etc. Have fun, Keith
Re: Dogwood
Re: Dogwood
tek-Brunswick, Ohio
>I've never turned green dogwood, so I'm not sure how difficult it is to dry. I've turned some tops out of dry dogwood from Lee Valley. It is hard and dense and very tight grained. I hear it is also tough. It takes detail and chatter work beautifully. I like it for tops because it is a light colored wood and shows up marker colors on the chatter work very well. It is worth turning. I would cut the pith out of the blanks before turning them. I have also heard that it was used for mallet heads.
Tom
Re: Dogwood
Re: Dogwood
Bob Herrman
>Hi Paul, I have turned quite a few bowls out of dogwood. It was green and turn easy. However when it drys it can change its shape. Make sure you dry properly. Although I have not turn Boxs, I would thing that the pit being off center might be a good thing. Give it a try and let us know.
Re: Dogwood
Re: Dogwood
Jennifer@Indy.USA
>Hi Paul,
Welcome to WoodCentral. I've never turned Dogwood before so I can't help you there....just wasnted to say welcome a board!
Let us know how it goes with the Dogwood.
Jennifer
Re: Dogwood
Re: Dogwood
>Paul I've tuned a fair amount of dogwood and have a 4 foot log than I need to do something with, right now. It will split quite easily when turned green unless you turn it thin like hollow onaments or this walled bowls. I have a mallet in the shop that I'm still using. It was turned out of seasoned dogwood and it split badly after a few months. I filled the split area with colored epoxy, carved and sanded it down and I'm still using it about 6 years later.
Keith had it right. If you want to use it for handles cut it up now and seal the ends and store it in a low heat area for a good while. When I have logs that I know I won't get around to using I try to rip them into 1x1,2x2, 3x3 and 4x4 blanks. I seal the ends and stack them on the floor. I never have dated them which I should because I always forget when I cut them but it takes about a year per inch to dry. I have found that you can use them before this time depending on what you turn.
Re: Dogwood
Re: Dogwood
Bob Elliott
>According to Dave Barriger, the old timers used dogwood for wedges to put in the kerf while sawing logs. Dave uses them today for chain saw work, instead of the plastic type.
The first pepper grinder I turned was from Jamaican Dogwood, but that reminded me more of a rosewood.
Re: Dogwood
Re: Dogwood
>I turned some dogwood that was so old it had turned pink. I'm not sure it was age that did it, but it was old, dry, and pink.
If I had limbs, and wanted to save them, I would cut them along the pith. Can't think how to explain this well, but I would cut so that the compression wood was all in one piece and the tension wood was all in the other. You will end up with a short half and a tall half. I would wax the ends and wait unless I was in a hurry and turned some of it green. The Idea here is that if you turned a bowl made from both types of wood, it would warp wildly, but if you separate the two types it may react more consistently. Great stuff to turn.
Re: Dogwood
Re: Dogwood
Arch
>Is there any difference in the timber's turning qualities or just in the blossom's color between pink and white dogwood? Russ will know. There's plenty of both in Tallahassee.
Re: Dogwood
Re: Dogwood
RussFairfield
>When freshly cut, the wood from the White Dogwoods was a bit whiter than that from the Pink which was slightly pink in color and often had red lines in it. There was no difference between them after the wood was dry. It all turned the same shade of pinkish brown, and the red lines disappeared.
Re: Dogwood
Turns great
Jim Reed @ Tallahassee
>as others have said. It was used historically for loom shuttles because of its smoothe texture. Also very good for tool handles. Very dense and beech like. Bad news is that the wonderful colors fade to ordinary browns. Good luck with your projects.
