Shavings for mulch?
Joel Hunnicutt
>Anyone using shavings for mulch? I know about the walnut toxicity thing, but I am mostly using maple. Not having much of a green thumb, is there any downside?
Shavings for mulch?
Joel Hunnicutt
Re: Shavings for mulch?
Mike Brazeau
>Joel - I gave a bunch to my sister-in-law a few years back. She has a very green thumb, and I had no complaints. I have read that you should let them compost a bit before spreading, but I know she did not. You know about the walnut and that is the only problem to my knowledge. Nurseries today use compost that includes ground up pallets for container planting of many woody type plants.
Mike
Stuart Johnson
>It is my understanding they rob the soil of nitrogen until they compost.If you don't compost them first add a fertilizer that is heavy in nitrogen.
keith zimmerman, Normal IL
>Small amounts of walnut shavings mixed with other woods will not harm anything. I wouldn't use shavings that are mostly walnut though. It will most likely be too toxic.
I cut up a box elder last fall and mixed all kinds of wood shavings into the branch mulch, including walnut, and let them sit all winter. I will be using this stuff as mulch in the flower beds this summer and do not expect any problems.
keithz
>Second the adding of some nitrogen. I have been using the sawdust and shavings on my autumn ferns (with a little nitrogen added - don't ask where I got it from ;)). They are doing well.
Keith Tompkins
>Hi Joel, I have been doing that for years. If you use it as mulch, you will have no problem. The problem occurs when you till it in...microbes in the soil tie up any available nitrogen in the soil while digesting the stuff, making the nitrogen unavailable to your plants. After the wood fibers are broken down, and the microbes die, they release the nitrogen back into the soil, eventually leaving it in better shape than when you started.
Composting it in a separate pile eliminates this problem.
Duane C.Leach
>The wood shavings are a great termite preventer.
Mix equal amounts of wood shavings, wood alcohol,and sand. Pour this mixture around the foundation of the house. The wood draws the ants. The ants eat the the wood and get drunk on the alcohol then stone each other to death with the sand.
Thuning is fun.
Duane
Lee Buck
>I just read Weedless Gardening by Lee Reich, a well regarded garden writer. He asserts the same thing. He recommends sawdust as a mulch and says the nitrogen deficiency problem occurs when the sawdust is tilled in.
Mike M
>Add grass clippings this will add nitrogen,and will speed up the break down of the shavings.
Bob Moffett
>Joel,
We use the shavings all the time as mulch. Walnut shavings go in a trash can for the garbageman to pick up. I was told that the dry shavings do better than green wood shavings, but haven't had a problem with either.
