We value your privacy.
>I just got my new Pachard tool catalog. and was looking at the new hold fast vacuum system. It seems that a vacuum pump is not need ed just an air compressor. I think someone should buy one of these things and let the rest of know if it works.
It sounds like a cheap way to have a vacuum chucking system. The hold system is priced at $230.
>You can get a 220v Gast pump for $89 and probably make your own system for less than that. That's what I plan on doing (since I don't have a compressor)
>That is called a venturi system. It takes an air compressor that can put out a large volume of air for quite a period of time. Most air compressors have 50% duty cycle motors and just letting them run burns them up. The venturi is cheap. The air compressor is expensive and has to be better than the average home air compressor.
Wanna have vacuum? Go with the dedicated pump. For a little more than $100 you can have everything you need. The other set up ultimately costs a whole lot more.
>I can only tell you that Nick Cook and Dave Hout have used this system very successfully. The chuck itself is very good in terms of fixing a blank. Depending where you have your compressor, the noise is much less than the pump I have. I think this is worth considering. If you make it to one of the local demos or to AAW, you can check it out. I think this is a very slick system and as one who has had a vacuum chuck, I plan on switching.
>I have a Gast Rotary Vane vacuum pump on my vacuum system and I would much rather have the noise of a 1/6 hp vacuum pump than hear my 5 hp air compressor come on. It does a great job and is much quieter than my air compressor. Personally, I'll stick with the vacuum pump.
>I made a venturi vacuum system years ago, cost about $10 in common parts. It worked OK, but was noisy and requires a pretty robust compressor (LOTS OF CFM) with a large tank. I also built a vacuum pump based system. I haven't used either in the last 7 years. I just use my shop vac and a few adaptors for holding the work. I've yet to lose a piece.
Silly question I know, but just which Gast pump do you all use? I have found the Gast UK site and have been amazed how many assorted pumps there are. So if you would be so kind ... model number/numbers please. I can then sort out the equivalent one for UK 240v 50Hz.
So I do not forget or cannot get back soon. Thanks in advance.
I think it is a bit small, but it has never let me down. I have a homemake drum chuck and a flat chuck. I bought a sealed ball bearing that fits in the race on the hand wheel on my NOVA DVR lathe and made all the other bits and pieces. I filed down a brass fitting to work in the inside of the bearing and put two O rings on it and pressed it in with the lathe. I put an O ring on "in front of" the hand wheel and use a piece of flat neoprene between the chuck and the should on the shaft of the lathe.
I suppose a somewhat larger pump would be better. It might also be wise to introduce a vacuum "chamber" in the line to "store" some vacuum.
I am considering doing some vacuum veneering and wonder if this pump is large enough. A larger pump could serve double duty. Also might be useful for vacuum clamping in (OH! NO!) flat work.
Someone gave me this very nice but small pump and it seems to work fine. With a little forethought, Vacuum might be almost as useful as compressed air in a shop.
