Re: Forceps?
RussFairfield
>Be very careful with those forceps, and NEVER hold them with any of your fingers inside of the loops.
TD had a little dog that did a good sanding job on the inside of hollow forms.
You might also try the "tumbling sanding" method. Fill the form to about 1/4 full with any abrasive sand or small crushed rock. Plug the hole in the top and rotate in the lathe at a slow speed somewhere below that where the sand is held against the sides of the vessel.
Tumbling works very well for wood that is uniforn in density and hardness. It doesn't work very well if there are soft spots. It gives an interesting texture to woods with alternate hard/soft growth ring.
