Wood turning software
JB
>I have tried the woodturner pro software and found it quit helpful, I was wondering if any has compared woodtuner pro to woodturner studio?
Thank you for your comments.
JB
Re: Wood turning software
Mark Kauder. Phenix City, AL
>JB:
Forewarning - I sell Woodturner Pro (Cheaper than you can get it from WooturnerPro.
I have and use both programs. I happen to prefer WTP, and happen to think that it will do most anything that most I need to do, and is relatively cheap. I also get good support from the WTP folks.
I know that Joel Hunnicutt uses Woodturner's Studio because he does a great many open segmented bowls. WS allows you to set the number of degrees between segments, whereas in WTP you set a distance. That means with WS regardless of the diameter of the ring, the distance in between segments is a constant scale.
I think that WS has a high learning curve. However, it allows you to color each segment so I can try out new color paterns. WTP only allows you to color each ring.
Mark
Re: Wood turning software *LINK*
Fred Holder
>I have Woodturner Studio and Woodturner PRO and 3D Design PRO. It takes both of the latter two to perform the same functions that Woodturner Studio will do. I've used Woodturner Studio to design an open segmented vessel that I turned. I've only used Woodturner PRO to design rings. Either one of them is very helpful in designing a segmented vessel. I think I'm partial to Woodturner PRO in conjunction with 3D Design PRO. I find them a bit easier to use. However, either program will be a great aid in designing segmented vessels.
Fred Holder's Domain Site
