Potential pot o' gold?
Thad
>All I know about this lathe is that it is a Yates 110v w/ approx 40" bed. I am curious if anyone "in the know" would consider this worth buying (gov. surplus) and restoring for my first lathe?
Thad
Re: Potential pot o' gold?
Thad
>Additional photo
Thad
Thad
Not sure what the right price is, but looks like
steve antonucci
>a pretty good piece of old iron.
Assuming everything works, and you've got a bit of time, could be worth the effort.
steve
Re: Not sure what the right price is, but looks li
Thad
>It's a government surplus auction currently well under $300.
>If it's 3 phase it may not be worth it unless you get it really cheap. It will cost you several hundred to buy a Variable frequency Drive to run the 3 phase. Check the spindle thread size if possible. It it's an odd size you can still get adaptors made but that adds to the expense also. Other than that it looks like a good piece of iron. The bearings could also be a problem but they are usually pretty inexpensive, it's getting the old ones off and putting new ones on that can be difficult.
Thad
>Thanks for the input so far. I have a converter for 3phase, and after more research I believe it is a Yates-American model J-170. I'm hoping that the bearings and wiring would be the only things required to get it running, so for < $300 I'm getting excited.
georgetroy
>Old Iron is good iron as long as you know what you are getting into. It's got to be better than a China Doll. GT
Walter Ahlgrim
>It would undoubtedly be a great spindle lathe. How ever few people have much interest turning spindles today. How long will you be happy turning bowls under 12 inches?
Most of us have limited time to spend on hobbies; this lathe looks likely to need 30- 60 hours work to me. Looks too heavy to get into sum basement shops.
Walt A
Looks like a real find
Brad Vietje
>You should have no trouble finding bearings for a Yates-American. You might also be able to turn outboard on this once the handwheel is removed, but you might need to use a floor stand tool rest, and most of those out there are junk. If you're looking for a real beefy lathe, this should keep you in small stuff and spindles for ever. You can always make a bowl lathe for bigger stuff if this model won't turn outboard. Restored, these go for $ 1500 - 2000+.
BTW, I don't recall where you are, but I saw a listing for a Blount lathe in working condition in Connecticut for $ 450.00.
Safe Spinning,
Brad Vietje
Newbury, VT
