200+ woodworking book reviews
grain on face turning?
Bob Fawcett
>When turning a face grain bowl is there a "preferred" orientation for the grain?
I notice that some of the wood I have has a pronounced curve to the grain from the growth rings. If I want to make a bowl should the curve of the bowl follow the rings? Does it matter? Does it have a known effect on the end product?
Re: grain on face turning?
Russell L. Babbitt Jr.
>I know of no difference as far as technique goes. Depending on how you face the blank you will get a different grain pattern on the inside of the bowl. All depends on your preference. If I can find a picture I will post it.
Dave Belser
>A bowl with the pith at the bottom will give you an oval pattern in the bottom of the bowl that changes to straighter lines working out from the center. With the pith a the rim you will get half circles on each side changing to straighter lines as you move to the middle of the bowl.
With the pith at the rim you can get two high spots when green wood drys out. You also risk checking on the rim as you approach including the exact center of the pith. For bowls with pith at the bottom, you can end up with a very week foot that won't hold up to chucking.
That said, a green piece of wood turned thin and dried slowly/evenly can be oriented almost any way you want with interesting warping as it drys.
The book "Turning Green Wood" by Michael O'Donnell has a pretty good explanation/exploration of this that applies to green or dry wood.
- Dave
