Handwheel Jet 1236
Ed Larson
>Has anybody installed a handwheel on a Jet 1236??? It should be easy to do but I can not determing the thread size of the internal thread on the outboard side of the head stock. Does anybody know the thread size????
Ed
Handwheel Jet 1236
Ed Larson
Ed
Re: Handwheel Jet 1236
Bruce Wolberg
>I have an old Jet 1236 and the thread on mine is 1/2-13 L.H. I took a short lenght of that rod and drilled it out so I could still use the morse taper knock out (the rod basicly becomes a nipple) and then made a handwheel with the same thread. There is not a lot of wall thickness in this arrangment but it has not broken off yet. Then I shaped the handwheel to hold a bearing for a vacuum system also.
Ron in Drums PA
>Jet sells hand wheels for a 1236.
