Worm Holes
Worm Holes
Worm Holes
HarryB
>I'm just finishing a little cherry bowl. It has aboout a dozen worm holes. Well, not really holes. Looks like the worm went through the wood and left behind the residue of the wood. The stuff looks like sanding dust but is fairly hard, though not as hard as the surrounding wood.
I'd like to get it out of the holes but working on it with a dental pick doesn't do very much towards cleaning it out. I've tried to disolve it with alcohol and paint thinner with no results.
Anyone have a method of cleaning out these holes while still retaining my sanity?
Harry
Re: Worm Holes
Re: Worm Holes
Allen Neighbors
>That residue is called "frass", and "worm poop"... your choice. I think it is deposited by the worm after it digests the wood, but I'm not sure about that.
Sometimes I clean it out with a piece of baling wire with the end flattened and filed like a tiny fingernail. I bend a loop in the opposite end to hold on to. I use an air gun to blast after I dig. It's very time consuming.
Sometimes the cleaned holes enhance a piece, and sometimes they don't.
Hope this helps.
Allen
Re: Worm Holes
Re: Worm Holes
>I do like Allen depending on how it looks. quite often I will simply put thin CA on it and continue turning. Experience will tell you when you should do which.
Re: Worm Holes
Dick Hines
Re: Worm Holes
Dick Hines
>I use a Dremel tool and a small burr. After grinding out the holes blow out the dust with air.
Re: Worm Holes
Re: Worm Holes
Jennifer@Indy.USA
>Harry,
Can you blow it out with compressed air? I've come accross some that is soft enough to do that.
Jennifer
Re: Worm Holes
Re: Worm Holes
>I select a twist drill bit the same diameter as the worms put it in a pin vise, and spin it in the hole between thumb and forefinger. Then, I fill the holes with dyed or pigmented epoxy.
Re: Worm Holes
Re: Worm Holes
Juergen
>Wet the track with water and the poop will pop, or qt least expand to make it easier to scrape out.
Re: Worm Holes
Re: Worm Holes
HarryB
>Thanks folks! I've had the most success with a small drill bit. I just found my pin vise and I'll try further holding the drill that way. Missed the suggestion on wetting the track so I'll give that a try too. Seems like a lot of work for such a small bowl! LOL Maybe it should go on the burn pile. I plan to fill the holes with either brass filings or coffee grounds.
Thanks again.
