grizzly lathe
byron
>Anyone have anl dealings with the g0584 or the g0462 lathes? They
look pretty good for the price.
Thanks, Byron
grizzly lathe
byron
Thanks, Byron
Re: grizzly lathe
Allen Neighbors
>Byron, I haven't had experience with either of those two lathes, but I do have a Grizzly 5979 12" X 36". I think you'll discover that the lathe is robust, and can take a beating. However, I've found that the tailstock isn't quite lined up with the headstock, but you can grind a little on the mount, and it will line up -- I did that.
Also, the ways are not trued along the bottom, so you can't just loosen the banjo and slide it from one end to the other -- it will catch in one place or another, and you'll continually be reaching under to loosen the mechanism, and that's a pain in the back.
The other thing I don't like about mine, is that I can't slow it below about 250 rpm. When you load an out-of-balance piece, that's too fast.
I wish I had searched more before I bought, I'd have a better lathe now. I'm now looking for bigger, and more precision... You get what you pay for.
Hope this helps you a little.
Allen.
Re: grizzly lathe
Bob Fawcett
>You can get a Jet Mini for less than $300. A bed extension is less than $100. Build a stand for it out of construction lumber and you have a great little lathe of about the same capacity.
If you ever decide to trade up a Jet Mini is easily sold.
Re: grizzly lathe
Rick Davenport
>Byron,
I have a Grizzly bandsaw and drill press.
They are a good value for the price
I am completely happy with them.
But I would not cut corners on my lathe.
Spend a few extra bucks on something that will last and that has good resale value.
Just one semi-rookie's opinion.
Rick
