Marks from Vacuum Chucking
George Van in WI
>I have just started using my Vacuum system. I got the Oneway 6� vacuum drum for my first and main one before I try to make the others. It came with a neoprene pad for the seal. I am using a Robinair vacuum pump. Most of the bowls I have mounted with this system have a ring on the inside from the chuck; I do not see the ring on the outside. Have others had this problem or is it unique to my system? My gauge is showing I am pulling 20� vacuum.
Re: Marks from Vacuum Chucking
>George Mine will occasionally leave a ring but it usually wipes out with a little steel wool. I have had it leave a bad ring in some lacquer. I suspect I didn't let it dry long enough or it was too thick.
George Van in WI
>John, these are on unfinished but final sanded bowls. They even appear on a hard maple plate/shallow bowl.I noticed them when i applied the finish. maybe they will disappear if I steel wool after the finish dries.
My experience...
Peter Teubel
>I've been vacuum chucking for years and I've had "rings" appear too. I have found they were caused by one (or more) of the following:
1) Wet wood. The vacuum draws any moisture thru the wood and can cause a "bruise". This will usually dissappear after it dries a bit.
2) If I sand an open grained wood under vacuum, dust will be sucked thru the pores and also form a ring on the inside. I blow it out with high pressure air.
3) Applying any liquid on the outside of the piece under vacuum will cause havoc (CA glue, finish, water, etc.). It all gets drawn to the inside and can make a mess.
4) *ANY* slippage of the piece on the vacuum chuck will cause the rubber/neoprene seal to abrade against the wood and can cause a ring. Again, high pressire air and some light sanding will usually take care of this.
Bill Hale
>I would not put any finish on until I was satisfied with the look. I believe if you finish over it it will only show worse
Bill in Casa Rrande, AZ.
Re: My experience...
George Van in WI
>Thanks Peter, the bowls were at 8% moisture. Thanks for the warning on finishing while under vacuum, you saved me some grief. It may have been slippage, I will be more aware on my next attempt.
George Van in WI
>Thanks Bill, I am going to wet the area to relax the compression and sand again with the last two grits.
