6" Tool Rest
6" Tool Rest
6" Tool Rest
Roger
>I have been looking for a Delta 6" Tool Rest with a 1" Post(46-805)and cannot find one. It would appear that Delta has discontinued this item. I have a Delta 46-755 16" Lathe and am in need of a 6 incher that can get close enough to work on small turnings. The round ones sold at Rockler etc. will not allow me to get any closer than about 7/8" on a 5/8" turning. Does anyone know where I may be able to aquire one? or should I just buy a 12" tool rest and cut it down?
Thanks
Roger
Re: 6" Tool Rest
Re: 6" Tool Rest
>Roger Powermatic has a 6" tool rest that is offset and lets you get very close to the turning. I have one for my 2035. They may make one with a short tool post. I would give them a call. They have 1" tool posts but you may have to cut it down to length for your lathe.
Re: 6" Tool Rest
Re: 6" Tool Rest
Fog Tanner
>Have you called Delta, they have been very good to me in finding those kinds of items. I have that lathe and the 6" tool rest you are looking for. I bought mine from The Cutting Edge in Houston, they may have more of then in stock as Steve carries that lathe. The problem in finding another is the way it is offset and the short post. I also bought one of the Best Woods round tool rest, but it has the problem of standoff from the wood. I use the post for the drill jig these days..
Re: 6" Tool Rest
Re: 6" Tool Rest
Phil in NJ
>The General toolrests might do what you want. I have
a spare 12" and 4" that I don't need...
Let me know if you're interested!
Re: 6" Tool Rest
I might have one
Phil Joines Krum, Tx
>From a ??-700 I added riser blocks to. What is the diameter and length of the post? If it fits you can have it for the postage.
Re: 6" Tool Rest
Re: 6" Tool Rest
Roger
>Gordon,
The Deltamachinery.com Web site "Service&Repairs", lists this part as "No Longer Available for Order", all other attempts to locate this item at other tool suppliers Web Sites results in the same response. I wonder if this is a sign of things to come since Black & Decker has acquired Delta Machinery. Delta's Great support for their equipment was one of the reasons that I have purchased many Delta Machines. It looks as if I may have to re-consider that in any future aquisitions. Thanks for the feedback.
Roger
Re: 6" Tool Rest
Re: 6" Tool Rest
Roger
>John,
Thanks, I will give them a call.
Roger
Re: 6" Tool Rest
Re: 6" Tool Rest
Roger
>Gordon,
Thanks, that looks promising. I will call them on Monday.
Roger
Re: 6" Tool Rest
Re: Phil & Phil
Roger
>Thanks for the very generous offers but it looks like Gordon and John may have steered me in the right direction. If worse comes to worse I can probably cut three inches off of each end of a 12" Delta Tool Rest and achieve the results that the 46-805 would give me.
Thanks again
Roger
Re: 6" Tool Rest
Richard Allen
Re: 6" Tool Rest *LINK*
Richard Allen
>Woodworkers supply has a 4" Delta toolrest.
Woodworkers Supply Delta Toolrest
Re: 6" Tool Rest
This site has a variety of choices
Guy in Cuba
>I have two sets of these and really like them. I prefer the longer posts.
http://www.cuttingedgetools.com/Onlinecat.htm/WebCatalog/Tool%20Rest.html
Re: 6" Tool Rest
Re: 6" Tool Rest
Roger
>Fog,
I called The Cutting Edge in Houston this morning. I was lucky enough to get the last one that they had in stock. They did say that Delta has discontinued this item and it appears to be a result of Black & Decker acquiring them. The Cutting Edge is not happy about the change of ownership. I don't have good vibes for the future of Delta products and support.
Thanks Roger
