Bowl Detal
Chris DiCiaccio
>Trying to learn to put a detail on the side of a bowl. This is a shallow bead try. More practice needed for sure. Small 3"x 1 11/2" maple.
Bowl Detal
Chris DiCiaccio
Re: Bowl Detal
Chris DiCiaccio
Re: Bowl Detal
Chris DiCiaccio
Re: Bowl Detal
Bob Fawcett
>Looks good to me Chris.
You sure are getting in the practice. I wish I had the time to turn as many.
Re: Bowl Detal
Jennifer@Indy.USA
>Hi Chris,
I agree with Bob....I sure do wish I had as much time as you to turn! I like seeing you trying new things and rim treatments in my opinion are fun things to use to add character to a bowl. They can be an element of design, or whimsy, added color, texture the sky is the limit! Have fun with it and try all sorts of things. You could even take this one you've made even father by adding some texture to the bead with a Dremel rotary tool, or adding some color with paint, or a marker. Or, sometimes....leaving the wood to do the talking is the right choice. The fun part of all of this is the exploring and it looks like you are certainly doing that. Another thing you may want to try is to set your bowl in front of a plain background when you take the picture. Even a piece of construction paper works well, or a pillow sheet. Anything large enough to fill the background. Also don't forget to shine as much light as you can on your subject :)
Keep up the turning!
Jennifer
Jennifer,
Chris DiCiaccio
>Thanks for the encouragement and those ideas. That opens up a lot of possibilities. I do want to learn to use the dremel tools to enhance some pieces. I hope to move on past, "just plain bowls" someday. As for the pics, as soon as I get a camera instead of this "camera phone" I believe I will be able to improve the clarity. My camera phone doesn't do close ups without blurring and it also makes my bowls look like the rims have an uneven thickness even when they don't. Anyway, I'm always open to helpful suggestions. Thanks again.
