Re: Turkey Calls
Kurt Aebi
>The way the little pot is setup, it's like a speaker type setup, where there is a friction surface on the top that you scrape the end of the striker across creating sound-waves. The smaller diameter glass below the slate top surface starts to vibrate and the sound waves exit the holes in the bottom. You hold the pot sort-of cupped in one hand working the striker with the other. The cupped hand acts like a deflector directing the sound out and away from you.
You would hold the striker down on the shaft ans scrape at about a 45� angle with little circular(actually like a "J")movements to make it sound like a hen turkey yelping (calling a Male turkey [Tom or Gobbler] to say "I'm Ready for the Spring passage, so to speak)and you can by moving th striker in different patterns simulate quite a lot of the turkey's vocabulary.
Hunters use these in the spring to "entice" the Gobbler into range for harvest. Not as easy as it sounds since turkeys have periferal vision of up to 300� and have the vision of a hawk (so to speak). They are afraid of everything as well, so they are constantly looking for movement. This on top of a shotgun only having a range of 50 yards absolute maximum, make it a rather challenging proposition. Some people are better at it than others - but it is cool to hear them gobble to your calls - if nothing else!
