Have a question? Ask Woody!
Mini Hollowing Tools
Don Orr
>I finally had some time this weekend to fire up my mini torch (MAPP gas & O2) to do some silver brazing and make some mini hollowing tools. The top one is going to be a "mushroom" tool to hollow on the right, the next 2 down will be for hand thread chasing ( taking a class at Brookfield Craft Center in May) and the others are various angles for regular hollowing. Now I need to find time to make the handles.
Re: Mini Hollowing Tools
Don Orr
>Forgot to mention they are made by brazing 3/16" HSS to plain carbon steel. Very easy to do, but you need serious heat, not just propane.
HarryB
>Don,
Can you get enough heat from MAP gas without the oxygen? You mention silver brazing. Is this the same as silver soldering?
Harry
>Yes the mapp gas alone works great. You will need some flux with the silver solder.
Sterling Sanders
>Hi Don. This is a good idea for making small hollowing tools. My only concern is the length of the cutter on the first, fourth, fifth, and sixth one. Not having the tip of the cutter in line with the shaft will make them prone to twisting in your hand. By bending the shaft to different sweeps of the "C" shape you can have the cutter inline with the shaft. The other three should work fine. Since your using them for quite small turnings you might be able to control them without misshap. Regards, Ster
>Sterling You are so right. I made one for hollowing ornaments that was longer on the end and I had to fight it too much. I now make them about 3/4" long. You can easily reach all parts of an ornament with a straight cutter and a short bent cutter.
I do have several that are bent like you suggest. Every now and then I design something that is hard to reach and these come in handy. That's why it's fun to build your own tools. You can make whatever works for you and your style of turning.
Wish I had the capability to work with HSS bar stock, both machining and heat treating. Then I would have fun making tools.
