We value your privacy.
>A while back I posted a question about belt sander for sharpening and got a bunch of good advice.I just wanted to say that I have not used my grinder since I got the belt sander.With a 100 grit alumina-zirconia belt my tools come out with a razor edge.I do my sharpening with the edge parallel to the belt,not perpendicular.Works really well.
>Pat, I've been using my little belt sander w/120 Grit belt since beginning turning 2 years ago. This idea of turning the cutter sideways is a good one. I've got to build a jig. Thanks for the idea.
>This is interesting, as Derek refers to a Mark II, but not THE Mark II. Woodcraft used to sell a fantastic machine called the Mark II that allowed the sharpening of all sorts of tools, both flat bevel and hollow ground, on a 4" wide belt sander setup with a 10" diameter drum portion, as well as a straight, flat platten for flat bevels (which I usually prefer).
Just an important aside, but if you get good results with the belt coming toward the edge, you'll get even better results with the belt reversed, and the abrasive running from heel to edge, and away from the cutting edge. Sideways, or roughly parallel to the edge, as mentioned above, also seems to work. Very simple jigs can be made to insure an excellent, consistant grind, and minimal removal of your valuable tool steel.
