Jet 1442 lubrication ?
Bill L.
>Having had a Jet 1442 for 2 years , I was wondering if the bearings need lubricating . The manual is not in the usual spot(suspect it's in shed under sawdust). The lathe has been a good one - only problem has been dust within the switch a few times; which was not hard to clean out. Or are the bearings "sealed for life" ? Thanks for any input in advance . Bill L.
Re: Jet 1442 lubrication ?
jdpeck
>You can find the manual here: http://www.wmhtoolgroup.com/partfiles/m_708358k.pdf
